DIY ring and pinion swap and LSD Q's.
Old Feb 10, 2006 | 11:03 AM
Alex-7's Avatar
There's been alot of buzz about R&P swaps lately and I'm jumping on the bandwagon.
I've got a 4.77 ring and pinion. It's in the whole third member from a small axel pre 84 car. I want to put that R&P in my 84 GSL-SE.
I've got a couple questions.
1. Should I do this swap myself? (I am easily frustrated) I've never really messed with a diff before. There is a Mustang shop here in town that obviously does alot of gear work and I've thought about trying to get them to swap mine.
If you've done this yourself, how hard was it and what is the risk of future problems due to improper instalation?
2. While It is all apart, should I do anything to my stock SE lsd (with 140k on it)?
These I've also never messed with before. Are they very complicated? Is it customary to rebuild them from time to time or just buy a new one?
If I buy a new one, Where do I get it? and ~ how much should it cost?
If I rebuild it. Is there a kit available? and where do I get it?
From the limited amount of time I've driven the car the lsd seems to work fine. But it does have some miles on it.
Thanks,
--Alex
Old Feb 10, 2006 | 11:14 AM
Midwest 7's's Avatar
sellout
get a book and do everything yourself.
quit being such a *****.
my 2 cents.
Old Feb 10, 2006 | 11:18 AM
Alex-7's Avatar
my 2 cents.
Bah!
I'd rather spend $200 than two days ******* with it if that's what it comes down to.
Old Feb 10, 2006 | 11:47 AM
Hades12's Avatar
Burning Oil-Grinding 3rd
Yea What he said.
Looks like someone needs to get a diff and tear it down with pics for all of us to see.
Old Feb 10, 2006 | 12:01 PM
Alex-7's Avatar
Thanks for all the great advice fellas!!!!!
Old Feb 10, 2006 | 03:27 PM
Siraniko's Avatar
RX for fun
Hey guys, I got more updates on the other thread...pix of kia
Old Feb 10, 2006 | 03:42 PM
seldawg's Avatar
Do it yourself and save money. I just pulled the 3rd member on one of mine to see if it was okay and it was a lot easier than I thought. If you swap the R & P the tolerances are what you need be concerned with the most.
Old Feb 10, 2006 | 03:45 PM
Siraniko's Avatar
RX for fun
I havent done ring and pinion swap. But since I took apart the extra non-LSD 3rd member, I may as well learn.
Old Feb 10, 2006 | 03:52 PM
Alex-7's Avatar
I don't have issues swapping a third member. I might have issues dissmanteling and reasembling one.
Thanks ^^ for all responses so far.
Old Feb 10, 2006 | 08:44 PM
Alex-7's Avatar
Bump for, Rotaryshack, RX7Carl or anyone else who's swaped gears before and can tell me what all is involved.
Old Feb 11, 2006 | 03:39 PM
Alex-7's Avatar
Or peejay, or drivefast7???
Saturday bumperoo.
Old Feb 11, 2006 | 10:22 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Sorry, I haven't swapped gears before. Just the whole pumpkin.
Need to be careful and setup the r&p and LSD just right, otherwise it'll chew itself up in no time flat. And ruin your parts.
I'd take it to a professional driveline shop, have it done right and forget about it. They usually warrenty their work too.
If ambitious, you can buy the mazda factory differential book and spend several hours trying to get it right. It requres some nice tools too.
Best of luck,
Brad
Old Feb 12, 2006 | 12:31 AM
85rotarypower's Avatar
love the braaaap
You can swap the R&P yourself, just take it to a competent shop to set it all up. There are very specific tolerances you have to setup in a diff and unless you have precision measuring equipment and a lot of patience, you need a shop to do it. Just take the assembled pumpkin and all the new parts, including the new R&P you want installed and they can do it for you. If this isn't set up right, the rear end is going to wear out real fast and whine like crazy.
Old Feb 12, 2006 | 02:17 AM
zduford's Avatar
Hopeless
feeler gauges! thats all we use at school when we do rear end work.....not to hard really, at least i dont remeber it being hard. But if ya dont have a clue as to what ur doing, just take it to the shop.
Or, pull the pumpkin out, and take both there and be like yah....put this one in here, and make work:S.....
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
ZacMan
Sep 19, 2015 09:20 PM
