Started my car yesterday....?
Old Feb 9, 2006 | 06:53 PM
rxtory's Avatar
Roll to Heaven in a RX-7
ok yesterday i started my car, the last time i was in it the clutch worked, but yesterday it was dead just flopping so I checked the fliud and it was full. what could be the problem is it not set in properly or has a linkage or cable come undone. I know nothing about how the clutchs goign to the traqnsmission, but i couldnt drive it cause there was nothing . but the last time i used it, it did work.
I did a search for this yesterday but i have no clue what to look under
any help would be appriciated
Old Feb 9, 2006 | 06:58 PM
Midwest 7's's Avatar
sellout
the clutch is hydraulic. little master cylinder by the brake master cylinder.
#1 check for fluid.
Old Feb 9, 2006 | 07:03 PM
rxtory's Avatar
#1 check for fluid.
did that there is fluid in it
Old Feb 9, 2006 | 07:11 PM
666mike666's Avatar
i just did my clutch i had to replace the slave cylinder and is the fluid brown?
Old Feb 9, 2006 | 07:13 PM
rxtory's Avatar
the fluid is old so yea it is brown would that effect it to much, i wasnt gunna absoultly drive the car yesterday so i didnt think i would need to change it just it was a bitch trying to get it back up the hill in my drive way
Old Feb 9, 2006 | 07:16 PM
666mike666's Avatar
yes that would effect it do you know how to bleed the clutch
Old Feb 9, 2006 | 07:19 PM
sellout
sounds like the slave is bad.
rxtory's Avatar
i have had to bleed brakes before, so wouldnt it be doing the same thig jsut to the clutch
Old Feb 9, 2006 | 07:20 PM
666mike666's Avatar
yes it is the same thing
Old Feb 9, 2006 | 07:26 PM
rxtory's Avatar
k i was hoping it was somehting like this rather then trying to track down a connecting rod or something. the only reason why i wouldnt think it would have been with the fliud is because no even 4 months ago it was wotking
Old Feb 9, 2006 | 07:29 PM
666mike666's Avatar
ya just try to re-bleed it and if still nothing then the slave cylinder you can pick one up at lordco for 25$
Old Feb 9, 2006 | 07:38 PM
cptpain's Avatar
Torqueless Wonder
wow....
Old Feb 9, 2006 | 07:52 PM
drittens's Avatar
that's kinda what I thought too
Old Feb 9, 2006 | 07:58 PM
rxtory's Avatar
hahahah well i have no clue lol. adn i didnt mean like a rod that would go straight from the pedal to the tranny i ment it from whenre the pedal goes from the inside to out
Old Feb 9, 2006 | 08:43 PM
Rotor13B's Avatar
Wassup!!
Have you tried to just let the car run and pump the pedal by hand? Sometimes you can get the pressure to come back up this way. I've had this happen in my SA before and it was a temp fix till I replaced the cylinder.
Old Feb 10, 2006 | 02:56 AM
rxtory's Avatar
no i never did that. we where mainly trying to get the car started but we noticed the clutch was dead so we dindt think much of it but now that it is running i gotta fix this so i can drive it
Old Feb 10, 2006 | 03:01 AM
gsterror's Avatar
Cholo with the Bolo
You don't NEED a clutch to drive your car.
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
torky007
Aug 17, 2015 05:14 PM
