2gcdfis wiring question
Old Feb 9, 2006 | 01:07 AM
vxturboxv's Avatar
recently ordered a coil from a member online. It was already pre wired but looks to be backwards on the ignitor wires. Should this matter? Also the ground wire from the ignitor is split off to ground the coil as well. Could this cause any problems?
I was useing this sight as a refrence.
http://www.geocities.com/inuissus_cendi/2gcdfis.html
Old Feb 9, 2006 | 01:18 AM
gsl-se addict's Avatar
Super Moderator
That looks all wrong. Is that red wire attached to the metal backing? If so, you need to disconnect it. Basically you want & wire going through the resistor to its terminal and the other going directly to the terminal.
What I mean, is that you could:
12v --> resistor --> coil +
coil - from stock --> 2nd gen -
or
12v --> coil +
coil - from stock --> resistor --> 2nd gen -
Old Feb 9, 2006 | 12:11 PM
vxturboxv's Avatar
So it shoudl be more like this?
Old Feb 9, 2006 | 12:12 PM
vxturboxv's Avatar
No the red wire is attached to the bottom of the igniter. It was FBII's coil I guess U two had spoke about a while ago and determined it was wired ok...
Old Feb 9, 2006 | 12:19 PM
Super Moderator
That is better. It looks like you have it connected to the -. It would probably be easier to put it on the + and connect 12v to the tan wire. You can then connect the - wire from the stock coil to the - on the 2nd gen coil.
That white thing is called the ballast resistor. The ignitor is missing from your coil.
Old Feb 9, 2006 | 02:37 PM
vxturboxv's Avatar
So if it's just a ballast its not directional right? So the way it is wired should work fine? I guess it worked fine the way it was wired on FBII's car I just wanted to double check.
Thanks...
Old Feb 9, 2006 | 03:03 PM
Super Moderator
Yes, it is not directional. It doesn't matter what side the resistor is on. You can wire inline to the + terminal or the - terminal. It just should be in the circuit. Some have ran without the ballast without problems. I would keep it just in case, though.
The Shaolin
Sep 14, 2015 07:50 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
