bitchest bolts/screws on an fb
Old Feb 6, 2006 | 01:02 PM
Midwest 7's's Avatar
sellout
definitly the 2 screws that hold the mirrors on or the 4 that hold the headlight cover on. they are soft as **** and always strip.
Old Feb 6, 2006 | 01:04 PM
aussiesmg's Avatar
Thunder from downunder
Two bolt beneath the fenders that attach them to the body, always break....IMHO
Old Feb 6, 2006 | 01:05 PM
rxtory's Avatar
Roll to Heaven in a RX-7
haha thanks for the heads up I have a problem with over tightening myself
Old Feb 6, 2006 | 01:07 PM
Alex-7's Avatar
As soon as i saw the title, I knew you started this thread midwheat.
LMAO,
The oil drain plug is tricky by my standards. And the valve cap.
Old Feb 6, 2006 | 02:49 PM
vipernicus42's Avatar
Rotoholic Moderookie
Lower bolt on the Brake Caliper Mounting Bracket!
and when/if you finally get in there, if you strip it, it's impossible to get it out to replace it!
Jon
Old Feb 6, 2006 | 04:12 PM
slashdawg00110's Avatar
RTFFAQ
bitchiest screws? the ones holding the ignitor facing the alternator
nastiest bolts? for me, the ones holding the strut assembly to the steering knuckle.
Old Feb 6, 2006 | 04:15 PM
Rotary13B1's Avatar
Bolt/nut- Clutch Master cylinder from inside. I hated that one.
Old Feb 6, 2006 | 05:05 PM
Dan_s_young's Avatar
Turbo widebody FB
Agreed, also the screws between the front of the dash and the windshield...
Old Feb 7, 2006 | 01:28 AM
nothingbutrotor2's Avatar
nothingbutrotor 1&2
Jon
Agreed. When I was changing my wheel bearing I really wanted to shoot something because of that thing.
Old Feb 7, 2006 | 01:42 AM
SparkienSuggah's Avatar
buzzzzz!-ook!-buzzzzz!
lower exaust manifold nut, rear rotor - with the racing beat setup. you just gotta use the wrench, i dont own a socket + wrench combo that will fit in there.
Old Feb 7, 2006 | 07:33 AM
clean85owner's Avatar
Nigga stole my bike!
If you are using a standard box-end/open-end wrench, the back right (when looking up the hood) bolt that holds on the carb. It's just impossible with a standard wrench with the stock motor/carb; but if take that wrench, put it in the vice grip, and smack the crap out of it a few times, it works like a charm.
I love how the Hayne's manual's only advice towards this bolt says something along the lines of: "The back right bolt holding on the carb requires a certain degree of patience."
Old Feb 7, 2006 | 08:44 AM
mooseknuckle's Avatar
i need a 20b in my fb
Jon
last weekend i found this out also. wat a bitch. i am going to grind a little of that metal away so i have enough room for my wrench to fit. i dont understand why they need to have that lip come out and block your access.
Old Feb 7, 2006 | 08:59 AM
edwin-82/rx7's Avatar
7-itis
the rear bolt for the oil filter pedestal. i stripped mine and can't really think of a way to get to it besides maybe dropping the tranny or pulling the whole damn engine!
Old Feb 7, 2006 | 09:23 AM
dj55b's Avatar
That stupid nut that holds the sturt cartridge in....
Old Feb 7, 2006 | 09:59 AM
Siraniko's Avatar
RX for fun
Jon
no need to take them off when changing your brake pad. remove the 17 bolt instead. If you ever need to remove the bracket, remove the entire strut assembly.
Old Feb 7, 2006 | 11:26 AM
matgls23's Avatar
Formula SAE Alumnus
The nut behind the steering wheel!
jimmydanny
Feb 8, 2010 06:03 PM
ppritchard
Nov 2, 2007 05:14 PM
