Is there a front air dam that works?
Old Feb 5, 2006 | 10:26 PM
aussiesmg's Avatar
Thunder from downunder
Looking for an effective front airdam that actually works and has a splitter, also like it to eliminate the front bumper, no ricer just old skool please.
Old Feb 5, 2006 | 10:35 PM
JoseReyes's Avatar
RicanRider
What about the one from mariahmotorsports???
http://www.mariahmotorsports.com
Old Feb 5, 2006 | 10:44 PM
aussiesmg's Avatar
Does not eliminate factory bumper cover, but nice in appearance, can't see if it has a splitter, probably not or they would state it.
Ah ha mode 4 is a replacement....nice
Old Feb 5, 2006 | 10:56 PM
nick1's Avatar
ya mode 4 is probably the best for a non widebody air dam.....what's a splitter btw?
Old Feb 5, 2006 | 11:00 PM
aussiesmg's Avatar
splitter is a tray under the airdam, creates a vacuum and keeps the front end glued to the road, it usually protrudes forward of the airdam creating the air splitter, this is what creates most downforce on the front airdam. The "airdam" is just that damming the air flow, reducing the amount of air forced under the car and lifting the front end at speed.
Old Feb 5, 2006 | 11:03 PM
JoseReyes's Avatar
RicanRider
Yes it does, you have to complettly remove the factory bumper down to the bumper shocks, then install the bumper support that comes witht the mariah mode 4 bumper... the attach the bumber......
Once installed it looks like the original bumber with the air dam. but the whole unit is fiberglass... the original bumber is gone...
Old Feb 5, 2006 | 11:08 PM
nick1's Avatar
side splitters. is this the usual black/carbon fibre flat piece on the corners of the air dams, usually with some type of collapsable spring or something holding them on?
Old Feb 5, 2006 | 11:12 PM
snwyvern's Avatar
Those guys (Mariah) have some quality gear, do they have any competetion... At all?
Old Feb 5, 2006 | 11:37 PM
85rotarypower's Avatar
love the braaaap
Not really. they've pretty much got that part of the market to themselves, as far as true functional units go.
Old Feb 5, 2006 | 11:43 PM
aussiesmg's Avatar
Side splitters usually start with "A Priest, a rabbi and a nun"
No really I think you are talking about winglets, they do a similar job by directing the air falling off the airdam to move up, pushing down on the winglets, thereby causing additional downforce. This originally ame out of F1 and has been used by many cars that lacked downforce in racing since.
Old Feb 5, 2006 | 11:52 PM
nick1's Avatar
okay...so a side splitter is what?.....
hey aussie was it you that was going to go coilover on your car? and if you have, how do you like it?
Old Feb 6, 2006 | 09:47 AM
Lt. Dan's Avatar
Any airdam that looks like the red one above will make a difference on the track.... As long as it has the "pan" from the main opening to the car... I definitely noticed a difference at speed with one mounted on the front of my car. The other nice thing is that instead of using the side buckets for foglights, you can cut them open, and run cooling vents to your front brakes... HUGE help on a first gen (less cracked rotors)
Dan
Old Feb 6, 2006 | 09:57 AM
JIMMY54's Avatar
GSL-SE PRO
mine is what you are looking for..... factory 3 piece made of flexible plastic. IMSA factory option. they come up for sale from time to time.
there are similar fiberglass ones at mazdatrix.com
Old Feb 6, 2006 | 11:12 AM
FirebirdSlayer666's Avatar
Famous Taillights
I'm just gonna fabricate my own front splitter out of sheet metal and attacth it to the bottom of the stock fascia. I want increased front downforce but I'm too cheap and I don't really want an airdamn
Old Feb 6, 2006 | 01:00 PM
aussiesmg's Avatar
If the splitter is too high off the ground it wont work, it must be close to the road to create the vacuum.
Old Feb 6, 2006 | 01:50 PM
Rx7carl's Avatar
Airflow is my life
It also needs to be rigid enough so as not to flex under load. The bigger the splitter, the more load will be on it. It should generate downforce at the front and pull the car closer to the ground.
Old Feb 6, 2006 | 03:05 PM
NewmanFirstgen's Avatar
Side splitters are called canards, in other racing circles
Old Feb 6, 2006 | 07:12 PM
aussiesmg's Avatar
Thats the word I wasthinking of.....lol :-D
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Wolf_
Aug 11, 2015 04:23 PM
