Canadian Forum Canadian users, post event and club info here.
Problems with "HOT START" help!
Old Feb 2, 2006 | 10:07 PM
FS_WTB's Avatar
After half & hrs of drive, i can start the car until the car rest 15mins or more
what do i need to do?
i just put on a set of new spark plugs and spark plug wires.
HELP
Old Feb 2, 2006 | 10:11 PM
now's Avatar
now
what it doing this before the plug change?
Old Feb 2, 2006 | 11:32 PM
vipernicus42's Avatar
Rotoholic Moderookie
I don't know about FCs or FDs, but hot starts for me always go better if I hold the throttle open a crack. Heck, the FB even had a "hot start assist" motor that cracked the throttle open to help hot starts, but I removed it because my foot can do just as good of a job.
Assuming your ignition and fuel delivery systems are good and your timing is alright, check your compression.
Jon
Old Feb 3, 2006 | 06:54 AM
FS_WTB's Avatar
it was the same after i change the wires and plugs in my FC
Old Feb 3, 2006 | 11:10 AM
eViLRotor's Avatar
Brother of the Rotary
Like vipercunnilingus said, check your compression.
If the car starts up fine and easy when cold, but has problems starting up when warm, you could be having compression issues.
It's fairly common with our cars, and a lot of people install fuel cut switches to help with this problem.
Old Feb 3, 2006 | 11:28 AM
now's Avatar
now
its either poor sealing intake gaskets or its time for a rebuild
Old Feb 3, 2006 | 11:46 AM
Alak's Avatar
My old 13B shows its age by doing this. I was told Cold plugs are part of the issue, as well as compression. I run carb on my FC so I have to mat it to get it to start warm.
Cold start consists of 3 pumps and hold it open 100%.
Ian_D
Oct 14, 2015 12:31 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
Monsterbox
Sep 11, 2015 03:29 PM
Enzo1944
Sep 6, 2015 08:57 AM
