What is the STRONGEST Jatco Transmission for drag racing?
Old Feb 2, 2006 | 07:47 PM
LUPE's Avatar
First of all, I hear a built jatco 3 speed transmission can be built strong and bolt straight up to a 13B.
Which of the JATCO transmissions are the best to build up?
Anyone know who offers trans brakes and performance parts for them?
I see that plenty of ausi guys are running 8's on this tranni.
Old Feb 3, 2006 | 03:18 PM
LUPE's Avatar
Anyone?
Old Feb 3, 2006 | 08:52 PM
ErnieT's Avatar
Living life 9 seconds at a time
What the hell is Jatco? You mean Jerico?? lol...
Old Feb 3, 2006 | 10:35 PM
silvr94r2's Avatar
Eric: Pm me if you want to get some more info. I'm doing a buy in so i can start building these here in the states. I've already got most of the stuff on it's way for mine and as soon as all the machine work is done and tested they will be produced and available for sale.
Old Feb 3, 2006 | 10:38 PM
Turbo II-FB's Avatar
a kryptonite transmission is the best! I run one now and I never have problems with super man when I'm causing mayhem!
Old Feb 4, 2006 | 07:43 AM
LUPE's Avatar
pm sent
Old Feb 4, 2006 | 11:06 AM
silvr94r2's Avatar
Originally Posted by LUPE
pm sent
and back to you as well
Old Feb 4, 2006 | 11:38 PM
I wish I was driving!
Japanese Automatic Transmission Company, IIRC.
They built the stock auto trannies for the second gen. Maybe for the third, too, I dunno.
Old Feb 5, 2006 | 05:57 AM
silvr94r2's Avatar
Actually every single distributor RX7 auto has a Jatco.....maybe other cars as well but those i know for sure.
Eric: you will need to find a 3n71b trans for your car if you want to do the built auto. They seem to be a dime a dozen until you start looking. I've had so many people offer to sell and i've only got 3 trans out of 12-15 people. Pain in the ***! Plus sourcing all the other needed parts is another pain but at least it'll be legal to run in the drag radial class. If your serious about it just keep in touch with me and we'll get 'er done.
Old Feb 5, 2006 | 08:09 AM
LUPE's Avatar
I'm very serious about it. I'm going to try and find a core to start out with. What year is the best? I want the 3 speed right?
Old Feb 5, 2006 | 08:27 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
hope this helps.....http://ausrotary.dntinternet.com/for...ighlight=jatco and also http://www.keas.com.au and this guy build billet valvebodies http://www.bmsproducts.com.au
Old Feb 5, 2006 | 08:41 AM
Rotaryhaven's Avatar
Total Rotary Domination!
Hmm, I have thrown these away in the past to include old school RX-4 auto trannies. AAAAAAAAAAARRGGGHHHHHHHH!!!!!!!
Old Feb 5, 2006 | 01:15 PM
j9fd3s's Avatar
Community Builder
and the mpv's and the nissan pathfinders, and others too. it was (is?) a joint venture between mazda nissan and ford.
Old Feb 5, 2006 | 09:20 PM
silvr94r2's Avatar
As long as it says 3N71B and has the R3A designation your set. Good luck finding one and someone to follow through. They should be pretty cheap being that they're pieces of poop unless fully built.
Old Feb 6, 2006 | 02:29 PM
LUPE's Avatar
What car/make/model and year does the 3N71B come in?
Old Feb 6, 2006 | 03:20 PM
crispeed's Avatar
'Tuna'
The '3' denotes it's a 3-speed so most early Mazdas and Nissans.
RX-2- 71-74
RX-3- 72-78
RX-4- 74-78
RX-7- 79-83
626- 79-82
B-2000- 83-84
B-2600- 87-88
GLC- 77-83
Honestly I know a lot of people that modified these things to the max and they were only good for about 4 or 5 runs in a full race drag setup, 500+hp. Just too small to take the abuse. Better off with a domestic tranny.
Old Feb 9, 2006 | 06:37 PM
Paradox_Racing's Avatar
FB Techie
I believe that JATCO builds almost every automatic tranny for almost all Japanese cars. (Correct me if I'm wrong) You may try looking for one from one of the higher powered JDM or export cars. You will still need to find a way to mate it to the motor though.
Old Feb 9, 2006 | 06:41 PM
LUPE's Avatar
The whole point in going with a Jatco is because they bolt right up to the 13B.
Old Feb 9, 2006 | 06:53 PM
ronbros3's Avatar
Opinion;; I would use a GM 350 auto , of course built up to serious HP levels, a power glide does not have a low enough ratio in 1st , so you DO have to adapt it , they have components to handle 600 ft lbs torque, 10,000 rpm.
Old Feb 9, 2006 | 06:57 PM
LUPE's Avatar
I'm still doing some checking on the Jatco. If that doesn't work out then a stalled/braked C4 is going in my car.
Old Feb 9, 2006 | 06:59 PM
T04Eneedy's Avatar
adiabaticly inefficient
i dont remember.are aftermarket tranny's legal in nopi?or are u not gonna run in the car in a class?
Old Feb 9, 2006 | 07:04 PM
LUPE's Avatar
To compete in the turbo6 class at NOPI, you need to use the stock transmission case.
I'm only going to run local tracks....... It's just a car to have some fun in
Old Feb 9, 2006 | 08:06 PM
silvr94r2's Avatar
It has to be a Mazda tranny which the Jatco is unless i've read the rules all wrong. The Jatco wouldn't be considered an aftermarket trans......stock RX7 trans. It doesn't say that it has to be of the same year. Hell look at the Honda's.....they all run different tranny's than stock.
Old Feb 9, 2006 | 08:33 PM
kabooski's Avatar
Laying Down Rotary Law
Valve Bodies and Shift Kits-
Stage II & III, Full Manual and Transbrake
Input and Intermediate Shafts
Billet Servo/Piston sets- Over Drive and Intermediate
Resplined Over Drive Hubs
Broached Forward Drums to suit large diameter Input Shaft
Cast Alloy Pans- Including Rotary R3A Transmissions
Billet Chrome Moly Nitrited 4 Pinion Planetary Sets
Relined Kevlar Flex Bands
Rebuild Technical Sheets
Old Feb 9, 2006 | 08:53 PM
RX794's Avatar
NYC's Loudest FD
You're better off using a built TH350 due to it being more efficient than a C4 tranny. Remember rotaries don't make as much torque as a piston engine and therefore need to get as much power to the wheels as possible, the C4 will eat up more of that power to the wheels.
