Fire - 5 RX-7 - 0
Old Feb 1, 2006 | 06:44 AM
AdragonsRX's Avatar
Relapsing rotor-head
Exclamation Fire - 5 RX-7 - 0
Well folks, that is fire #5 for the SC crew in the past year that I know about. Sitting in the Arby's drive-through I noticed a bit of smoke coming from the undercarrage. I shut her down and got out and got an extinguisher from the stupid woman in the window and put out a small fire. It looks salvagable, appears it started from a FPD that wasn't even 3 years old but I haven't had a good chance to look yet. Didn't even hot-spot the hood so I may have gotten off lucky. I'll keep everyone updated.
Peace,
Justin
Old Feb 1, 2006 | 10:15 AM
Tim Benton's Avatar
FD title holder since 94
Be thankful the stupid woman gave you the fire extinguisher.
Tim
Old Feb 1, 2006 | 10:17 AM
Whizbang's Avatar
Respecognize!
more like PD - 37847902867 Rx-7 - 0
Old Feb 1, 2006 | 10:24 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
Glad it turned out mostly ok, it could have been a lot worse. I think i may be #6 (or #37847902868) b/c my 88 se has a strong smell of fuel sometimes. I need to check the pd too
you may just be able to eliminate it, just replace it with a banjo bolt http://fc3spro.com/TECH/FAQ/pd.html
what all was damaged? if you need any parts, i have a garage full of S5 n/a parts if you need them
Old Feb 1, 2006 | 12:08 PM
AdragonsRX's Avatar
im not sure yet what all is fragged, the fire was straight up from the FPD so everything north of that pretty much, lots of vac lines and stuff, need to get under the mani and check the oil injectors and see about the TPS, got just a little cooked wiring but overall not too bad, i can rebuild it i think
Old Feb 1, 2006 | 01:40 PM
Derek10AE's Avatar
Shake-zula, the mic rulah
Justin,
I feel your pain...I am still trying to get mine running right after my engine bay fire. Atleast she is running once again.
I'll be in charleston till Monday if you want some help give me a call.
Derek
Old Feb 2, 2006 | 09:45 AM
AdragonsRX's Avatar
Here is the run-down so far:
Throttle Position Sensor - 191.30
Primary Fuel Injectors x2 - 283. 38 ea (566.76)
Fuel Pulsation Damper - 143.30
FPD Seals - 5.00 total
Oil Injectors (Manifold) - 43.76 ea (87.52)
Oil Injectors (Housing) - 28.30 ea (56.60)
Oil Lines:
Front Housing - 21.96
Front Intake Manifold - 23.63
Rear Housing - 23.83
Rear Intake Manifold - 25.26
Vacume Spider - 47.80
Various wiring and vacume lines.
Well there ya go, if anyone knows where I can get this stuff cheaper let me know, these prices are all from Mazdatrix.
Thanks,
J-dub
Old Feb 2, 2006 | 06:49 PM
Tim Benton's Avatar
try getting them from mazdapartscheap.com
Tim
Old Feb 3, 2006 | 11:08 AM
Tim Benton's Avatar
looking at Mazdapartscheap.com
primary fuel injectors x2 (260.01) - $520.02
FPD - $138.06
throttle position sensor - 174.60
For just those 3 items- you'd save $69
Tim
Old Feb 3, 2006 | 11:27 AM
AdragonsRX's Avatar
thanks tim, im going to check it out later
Old Feb 3, 2006 | 01:50 PM
Tim Benton's Avatar
I take that back...since the prices I listed were for an FD not the 1988 model you needed. But their prices do seem to be cheaper than most so it wouldn't hurt to check it out none the less.
Tim
Old Feb 3, 2006 | 08:46 PM
sevensheaven's Avatar
REPU Wanter
You need to talk to Ray crowe up at malloy mazda in Virginia, I just got an FPD for 105. and change. I don't have the number handy but you can search it pretty easy. Need to mention the forum when you talk to him!
Terry7
Old Feb 6, 2006 | 02:25 PM
rotorchick's Avatar
ridin' dirty
Justin,
Stop lighting your car on fire !Here is the link to where I got my hoses from:
http://www.hosetechniques.com/
I'm pretty happy with the price. I have every silicone vacuum line I could possibly need for less than $100 shipped and it got here in like 2 days I think. On a side note, I was supposed to put the engine back in the car this weekend but I will be too busy so it will have to wait until the following weekend. Of course it doesn't really matter since I'm still missing parts . Next step is painting the motor. Zach suggested yellow. Ummm, how about no. I have some pics I will be sending you, Derek, and Nieto shortly
West Siiiide!!
That will teach you to jack our threads !
Old Feb 6, 2006 | 02:26 PM
rotorchick's Avatar
ridin' dirty
oh and that price is for an FD
Old Feb 8, 2006 | 06:12 AM
AdragonsRX's Avatar
i found the cause of the fire............. a little copper washer that fits between the rail and the line fell off when i was pulling everything off the parts car so when i put everything on the GTU that washer was not on there........... result..... $230.00 worth of repairs.
Old Feb 8, 2006 | 06:29 AM
speedracer2235's Avatar
blackhole on wheels
How about a pair of injectors from R/C engineering? I got a pair of 550s a while back for $99 ea. The hell with the factory ones! Are you trying to keep the emmisions? I had the Blue FC down to 3 vac lines.
Old Feb 8, 2006 | 07:42 AM
gxl90rx7's Avatar
well i pulled the UIM of the 88 SE, and sure enough the gas smell was the pulsation damper. I popped the plastic cap off it, and teh screw just fell out, it must have been leaking for a while, im lucky it didnt go up in flames too!
Anyway, so im going to try the banjo bolt PD thing. Im going to do the rats nest removal while everythings apart, hopefully i wont screw anything up
toplessFC3Sman
Mar 20, 2018 01:54 PM
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
Monsterbox
Sep 11, 2015 03:29 PM
windom
Sep 11, 2015 04:48 AM
