Popular wideband
Old Jan 29, 2006 | 02:13 AM
Popular wideband
Just wondering what wideband kit most of you guys use.
I was looking at the PLX R500 and the Innovative units.
Old Jan 29, 2006 | 09:01 AM
limbar85's Avatar
mhhh
Veteran: Air Force
innovate is awesome. ive got the lc-1
Old Jan 29, 2006 | 10:46 AM
Rotortuner's Avatar
Undercover
How easy/hard is it to get the inovative to graph AFR vs. RPM? I know you need a laptop, but how hard is it to get it to sense the RPM? Sorry if this is a dumb question, but just curiouse. thanks.
CJG
Old Jan 29, 2006 | 01:37 PM
limbar85's Avatar
mhhh
Veteran: Air Force
i have it hooked up to my datalogit so....
Old Jan 29, 2006 | 02:26 PM
Are you guys running the O2 full time? Or unplugging it afterwards?
The PLX taps into the stock O2 wiring not sure about the Innovative
Old Jan 29, 2006 | 05:43 PM
Jim Swantko's Avatar
Fjo
Old Jan 29, 2006 | 05:57 PM
kenn_chan's Avatar
Savanna Rx-7
limbar,
how difficult was it to get the datalogit, and the innovate to talk with each other?
kenn
Old Jan 29, 2006 | 06:14 PM
Corusco's Avatar
I use a PLX R500 on my 4Runner...it's a great unit if you want to have a display for both Lambda and EGT all the time. It's also an easy setup. The Innovate goods are a little more techy but definitely powerful. I would get the LM-3 auxbox to go with the LM-1 for a lot of great logging.
I would like to know how you got the LM-1 and the Datalogit to work together too, limbar...
Old Jan 29, 2006 | 06:27 PM
BLitzed33's Avatar
EFI systems wideband
Old Jan 29, 2006 | 06:37 PM
limbar85's Avatar
mhhh
Veteran: Air Force
all the information ud ever need. its an easy hookup/setup
https://www.rx7club.com/showthread.p...light=innovate
Old Jan 29, 2006 | 08:55 PM
RotorJoe's Avatar
Hooray For Boobies!!!
/\ X2
Old Jan 30, 2006 | 04:52 PM
Corusco's Avatar
Rock on! Thanks
Old Jan 30, 2006 | 11:54 PM
Indian's Avatar
It wasn't me!!
PLX-R500 .Has firmware updates and is a blast, check it out. Very acurate and has a 90 minute data logger on the flash.Also does coolant temp, egt, afr,boost,shift light,speed,rpm,knock sensor,G's. And more to come, everytime a new firmware comes out!!
Here's the link, plxdevices.com .
Check steve at gotham and Cam at pettit. they love it .
Old Jan 31, 2006 | 12:20 AM
crispeed's Avatar
'Tuna'
The Innovate XD-1 wideband gauge monitor is probably one of the best in it's class. One of the best features of this gauge is the warning light function. It's not just max/min A/F values that are recorded but you can program a certain A/F based on TPS, Map etc to activate the warning light.
Check out the manual for the rest of the features.
http://www.innovatemotorsports.com/s...Manual_1.2.pdf
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
mulcryant
Oct 4, 2015 12:18 AM
