Dyno today
Old Jan 19, 2006 | 10:57 AM
PhatManBUD's Avatar
Dyno today
So i let my friend take my car today to his school (UTI) to dyno it at 5 psi and check the afrs. Too bad my 10psi spring didnt come in in time. =(
but i will be dynoing it again once i get it in.
Lets see what the kit makes at 5 psi
Old Jan 19, 2006 | 11:00 AM
Wargasm's Avatar
Weird Cat Man
Post it up! And please list all turbo specs that you know for your car.
Old Jan 19, 2006 | 11:19 AM
PhatManBUD's Avatar
I will post the results once i get them.
I dont know what exactly the turbo specs are, other then the a/r is 1.15
But the mods im running is
Im running:
Streeport
PowerFC
FMIC
hks ssq bov
3" straight with Borla XR1 muffler
Trust Catback
50mm w/g
pulleys
koyo radiator
crane hi-6 ignition amp
magnecor wires
1680cc injectors
kieth rail
sr motorsports 9.5lb flywheel
6puck clutch
no a/c
I have a few questions for you guys if someone can please answer them:
-If i see how much i make at 5 psi. would using the theory that 1psi = 10 hp. be accurate at estimating what i would make at 10-14 psi.
-Wouldnt 5 psi be below the efficiency range of the turbo, and i would gain alot more by running 10-14?
-If the maps are pretuned on someone running 14psi. wouldnt that greatly affect the performance at 5 psi because the car is running super rich?
-So is it possible i see a gain of more then 10hp per psi because the mixture is leaning out more, and it is going to be a better range for the turbo?
Old Jan 19, 2006 | 02:09 PM
RotorJoe's Avatar
Hooray For Boobies!!!
I thought you had a 60-1 or very close to it?
I'm curious what your numbers are also.
Thanks
PhatManBUD's Avatar
Booooo, they wouldnt let him dyno it cause it leaked one drop of oil! BASTARDS!!!! AHHHH welll...im gonna put in that 10 psi spring and go get it dynoed some other time...
can someone still answer my questions?
Old Jan 19, 2006 | 03:59 PM
cewrx7r1's Avatar
Eye In The Sky
Thumbs down
What type of bull **** is this?
Old Jan 19, 2006 | 04:11 PM
PhatManBUD's Avatar
word.
do you know how long it took me to finally give up the keys so he cud take it to school and dyno it...and they cant even do it!?!!!!!!! well...he finally convinced me by showing me his insurance card (full coverage on any car) and giving me the keys to his 95tt supra. hahaha.
rawr
he said that like 60 people dropped everything and came and crowded around the fd. hahaha. theres not 1 at the school what a rare site to see for them.
Old Jan 19, 2006 | 04:12 PM
PhatManBUD's Avatar
Aiming for 300whp at 10psi.
Old Jan 20, 2006 | 07:02 PM
angelck022's Avatar
That turbo actually spools pretty good, I made 300rwhp @ 8psi with similar mods, you should have no problem hitting 300+ @ 10psi--assuming the turbo holds together .
Good Luck and post your numbers!
Coochas
44
Nov 5, 2019 11:08 PM
Rotate86
May 18, 2018 02:44 PM
Andrew7dg
Aug 6, 2017 01:41 PM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
Sh00bs
Oct 1, 2015 11:57 PM
