Garrett now offering Full Ball Bearing CHRA for T3/T4
Old Jan 17, 2006 | 01:56 PM
RacerXtreme7's Avatar
NASA geek
Read it in a little side product note in Turbo mag. Garrett now offering standard T3/T4 CHRA centers in full ball bearing. Now we'll be able to run the new Garrett GT steel bearings with the older T3/T4 turbines and compressor wheels along with all the turbine and compressor housings. If you need to rebuild your older turbo, now you can just order a ball bearing CHRA and swap over your parts (back plate, compressor wheel, comp housing, turbine shaft, turbine housing) I'm sure you'll need a full VSR balance. I have no idea on pricing or even how to get them (I've been out of the turbo sales/rebuilding loop for a while and havent kept in contact with my vendors). Like I said, I just saw a snippet of it in Turbo mag. I'm sure, they'll only come in water cooled.
~Mike............
Old Jan 17, 2006 | 02:10 PM
NASA geek
Just a side note.
Up until now, the only way to get a Garrett ball bearing center was to buy the newer series GTXXXX "R" turbos. You could have purchased a ceramic ball bearing center from Turbonetics which really is only a single bearing, or buy a full dual ball bearing (ceramic as well) from Innovative Turbo systems (both available in standard T3/T4 frames). OR go the really really expensive route of getting an IHI turbo which are extremely hard to find and even harder is finding flow maps and different A/R turbines (these are mostly found in kitted turbos from say Apexi). Now you can get the Garrett steel ball bearing benefits (quicker spool, less oil use, less energy to keep the turbo spooled etc) with Garrett reliability. I don't work for Garrett, just a fan and at one time sold and rebuilt them. I'm just passing this on to fellow gear heads.
~Mike.........
Old Jan 17, 2006 | 03:58 PM
KNONFS's Avatar
B O R I C U A
Those are GREAT news!
Thanks for the info
Old Jan 18, 2006 | 12:29 AM
RETed's Avatar
This
Is
Useless
Without
Prices???
You probably don't have any clue on pricing, but I have this bad feeling it's not going to be cheap!
It's bad enough that some of the Garrett GT-series stuff is Made in Mexico!
Garrett is making a killing on the cheap labor!
-Ted
Old Jan 18, 2006 | 09:42 AM
NASA geek
Did some poking around. ATP offers this but has yet to list prices. CHEAPTURBOS.COM aka Pheonix turbos so far offers this to any turbo build at an additional $499.00. ouch.......
http://www.atpturbo.com/
http://www.honda-tech.com/zerothread?id=1388103 <-- found Cheap turbo's talking about it here.
I'm sure any Garrett dealer / distributer will be able to offer this.
~Mike..............
Old Jan 20, 2006 | 02:08 PM
Turbo II FC's Avatar
Total Balance is Key
The shop I work at offers this as well. Its alot cheaper than what RacerXtreme7 posted. Check it out. www.boostlogic.com
Old Jan 20, 2006 | 02:20 PM
NASA geek
WOW!! Thats a great price (extra $200 for BB upgrade). its just a matter of time b4 price wars/cut throating will make these cheap.
~Mike..........
Shainiac
Sep 3, 2015 10:08 AM
Engine stand ready
Aug 14, 2015 10:26 PM
Turblown
Aug 14, 2015 04:48 PM
