Torsen Helical Gear Lsd
Old Jan 11, 2006 | 04:44 PM
TOOSHORT_88's Avatar
"On the grind"
Thumbs up Torsen Helical Gear Lsd
Hey i came across this on ebay. i was thinking about getting it but i dont know if it is any diffirent from a regular lsd or set at a good price $324..95 any info would be great thks..
Old Jan 11, 2006 | 04:55 PM
"On the grind"
Helical Gear LSD - RX-7 RX7 FC3S Turbo
Old Jan 11, 2006 | 05:59 PM
hornbm's Avatar
FD > FB > FC
I wouldnt use it for hardcore drag launches
What kind of driving will you be doning with the car?
Old Jan 11, 2006 | 06:07 PM
"On the grind"
street
Old Jan 11, 2006 | 06:10 PM
hornbm's Avatar
FD > FB > FC
yeah, its the all around best type of LSD i think. Allows you to transmit the maximum ammount of torque to the ground. But the stock clutch type LSD is stronger
Old Jan 11, 2006 | 06:46 PM
Rotortuner's Avatar
Undercover
S4 was clutch type and S5 is torsion. So thats just an S5 torsion type.
CJG
Old Jan 11, 2006 | 08:42 PM
"On the grind"
so should i get it i dont have lsd of any kind
Old Jan 11, 2006 | 08:43 PM
"On the grind"
and if i do get it can i just put it in my pumpkin with no modifacations?
Old Jan 12, 2006 | 01:55 AM
hornbm's Avatar
FD > FB > FC
CJG
s5 is viscous dude
Old Jan 12, 2006 | 02:02 AM
Hyper4mance2k's Avatar
The Shadetree Project
some people, huh?
Old Jan 12, 2006 | 05:40 AM
Boost Lee's Avatar
Dark Lord of the Drift
Hey tooshort... when you did the conversion, did you put a turbo rear end in your car? If not, that TORSEN won't work. It's larger than the non turbo differential, and won't fit in the non turbo casing. The TORSEN is only a replacement if you already have a turbo rear end...
The conversion includes:
Differential
Rear axles
Driveline
probably transmission as well (i think there are some length differences between turbo and non)
Old Jan 12, 2006 | 08:05 AM
"On the grind"
shitt.. back to the drawing board
Old Jan 12, 2006 | 08:29 AM
hornbm's Avatar
FD > FB > FC
well a torsen from a miata would work if you have the non-turbo rear end. They also have the 7" ring and pinion.
Mazdatrix sells it as a direct replacement on their site
Old Jan 12, 2006 | 10:01 AM
Boost Lee's Avatar
tooshort, you could go to the junkyard and get the conversion off of that turbo car, just incase you want to be ready for your conversion. It will all bolt up to your car. Then you could put the torsen in whenever.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
