Which spark plugs to use?
Old Jan 5, 2006 | 01:16 PM
PhatManBUD's Avatar
What spark plugs should i used now, since im boosting and im broken in?
All stock leading?
or
Stock leading and trailing?
or
Something else?
Also, does it make a big difference running all leading plugs vs stock leading and trailing?
Old Jan 5, 2006 | 01:33 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Search works wonders! It also depends on your setup. What turbo are you using, what kind of power are you shooting for?
Old Jan 5, 2006 | 02:22 PM
PhatManBUD's Avatar
I know i tried searching like
"All leading plugs"
"Spark Plug Setup"
stuff like that. nothing answered directly. Basically all i wnated to know if im running single turbo should i change my sparkplugs to all leading or something? I have a crane hi-6 ignition amp. I just wanted to make sure my ignition is sufficient. Right now on this turbo im aiming for 300-350 whp. But in the future 400-450 whp.
Old Jan 5, 2006 | 02:24 PM
LUPE's Avatar
"All leading plugs"
"Spark Plug Setup"
use all stock 9's
Old Jan 5, 2006 | 02:52 PM
PhatManBUD's Avatar
so thats the Bureix9s or whatever right? k gotcha
Old Jan 5, 2006 | 03:24 PM
RotorJoe's Avatar
Hooray For Boobies!!!
Originally Posted by LUPE
use all stock 9's
Also here is a great link about spark plug heat ranges.
http://www.ngksparkplugs.com/techinf...000&country=US
Old Jan 5, 2006 | 05:52 PM
PhatManBUD's Avatar
great, thanks
i think ill be changing out my sparkplugs to all leading this weekend. Break in is over with and its about time for my 2,500 oilchange. still on same plugs as before.
Old Jan 5, 2006 | 06:15 PM
RotorJoe's Avatar
You mean all trailing, the 9's
It’s a colder plug (smaller insulator) so it will dissipate the combustion chamber’s heat faster.
Old Jan 6, 2006 | 02:57 AM
PhatManBUD's Avatar
oh really? ok all the trailing ones. ill make sure to remember that. someone todl me all leadings WTF.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
