Cheap Bastard fix for clutch switch
Old Jan 1, 2006 | 02:13 PM
adam c's Avatar
Cheap Bastard
Talking Cheap Bastard fix for clutch switch
My friend Kory ("kory_yahi" on the forum) recently bought a 93 R1. He brought it by one day to show me his new ride. Its a pretty nice car . Black on black. All stock except for a nice RB catback. He let me take it for a short drive. While we were out, I noticed that the clutch engaged a bit high, and that the idle was around 1200, and wasn't smooth.
A few days later, I invited him over to see about fixing the clutch & idle. I started by adjusting the clutch pedal. It had virtually no play in it. I used a 12mm wrench to loosen the lock nut, and adjusted it properly. After tightening it down , I checked out the clutch switch. When depressing the clutch pedal, the white "button" didn't come out. It's supposed to pop out when you depress the clutch. I unbolted it with a 17mm wrench, and took it out of the car. I told Kory that it was bad, and that it was not an expensive part to replace. Maybe around $20?? Then I remembered that I am a "Cheap Bastard", and I decided to try and fix it. I couldn't get the button to come out, so I decided to take apart the switch. There are 4 metal tabs on the bottom of the switch. I carefully bent them up with a pliers, being careful not to break them. Once the tabs were bent, the plastic slid right out, and all of the parts became accessible. What was once a functioning spring, was now a rusted, broken pile of little coils. No wonder it didn't work. After a few minutes of looking in my "spare parts" (nuts, bolts, etc.) drawer, I didn't find a spring. Hmmmmmmmm ...... now what?? And there it was. A simple ball point pen. Just sitting there on my work bench. Nah. That can't work. That would be too lucky. I opened up the pen, and took out the spring. Sure enough, it fit perfectly . I reassembled the clutch switch, and installed it.
Kory started the car, and the idle was now as smooth as can be. A quick adjustment of the air adjustment screw, and the idle was now perfect.
Sometimes even a "Cheap Bastard" gets lucky
Old Jan 1, 2006 | 03:29 PM
Kory_yahi's Avatar
Look ma'! I am spoolin'!
This thread should be stickied! "How to re-man your clutch switch" :P . Thanks again adam .
Old Jan 1, 2006 | 03:32 PM
Cgotto6's Avatar
Haha. Nothin wrong with a cheap fix. Who would have known the potential fixing power a ball point pen could hold?
Old Jan 1, 2006 | 05:51 PM
Snotcycle's Avatar
Furious Ass-Monkey
post pics and get mahjik to sticky =)
Old Jan 1, 2006 | 06:24 PM
level7's Avatar
Search Button Advocate
LOL sticky? come on fellas, cheap fixes are great and all but i dont think it should be the standard for fixing problems. dont get me wrong, adam c's fix is sweet. with all the noobs lately they may get the wrong idea. well...its not like they read stickies anyway
Old Jan 1, 2006 | 06:31 PM
MakoRacing's Avatar
Where has my $ gone?
Hahahaha good thinking adam
Old Jan 1, 2006 | 06:59 PM
littlemilla3's Avatar
Haha I did the exact same thing to fix mine.
Old Jan 1, 2006 | 07:09 PM
RotaryX's Avatar
ROTARY AUCTIONS
LOL, That's awesome. Reminds me when I had a short in my engine wire harness, and I went out and bought a 200ft roll of speaker wire and made a homemade wire harness. True Story!
Old Jan 1, 2006 | 10:23 PM
Improved FD's Avatar
you forgot to indicate what pen it was, the most important part
all pen springs are NOT created equal, I've taken them apart for fix a flowmeter before (not automotive related)
Old Jan 1, 2006 | 10:56 PM
poss's Avatar
Slower Traffic Keep Right
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/easy-fix-broken-clutch-switch-423749/
Old Jan 2, 2006 | 02:25 AM
jeffrored92's Avatar
It's been 7 odd months now since I fixed mine this way (see linked thread with pics) and it's still working perfectly
I can't see why anybody would buy a new clutch switch because the spring failed, when it's so easy to put a new spring in it. Now if the contacts were dodgy, and couldnt be cleaned/fixed, then that's another story.......
Nice work Adam
Old Jan 2, 2006 | 01:55 PM
adam c's Avatar
Cheap Bastard
I guess its hard to be the first one to do anything on a 12 year old car
Old Jan 2, 2006 | 04:19 PM
riptor's Avatar
lol ^
Old Jan 2, 2006 | 05:23 PM
poss's Avatar
Sorry to rain on your parade. I'm sure there are plenty more ways to be an original "cheap bastard." I recently had this problem too, that's how I found the thread that I linked.
Old Nov 3, 2006 | 07:16 PM
WaLieN's Avatar
Call me gramps!
I recently had an idle issue where it would bounce from 500-800rpm in idle while in gear. Well, turns out the spring inside the clutch switch was broken in three pieces, not allowing the plunger to make contact with contacts. Well, a dead pen and 10mins later, the problem was solved.
Old Jan 13, 2007 | 11:31 AM
danny hahn's Avatar
Dear Mods,
This fix is deserving of a sticky or at least a spot under FAQ and other useful links.
Fast and easy r&r of a ballpoint pen spring, an efficient use of time. No phone calls to order or waiting on part.
17mm wrench to remove, needle nose and flathead to open tabs, standard ball point pen spring, channel locks to squeeze tabs back down. then back under the dash noting how many threads forward and back of the nuts (5 forward, 3 back, anybody had different #'s?).
My car was stalling on cold start idle when letting the clutch out, PFC indicated no clutch when depressed, I had about 1/4" of plunger on the clutch switch showing instead of a 1/2" which wasn't enough travel outward to activate the switch.
Most of the threads regarding this fix seem to be about stalling when coming to stop and depressing clutch. My symptom was getting a load on startup, having to double clutch or let the clutch out slowly, often I would stall and the ensuing startup would be a backfire, thoughts of breaking apex seals concerned me.
It took more time for me to post this than to do the repair. I'm going to let the Power FC relearn idle. Thanks Adam C you Cheap Bastard!
Old Jan 13, 2007 | 12:26 PM
adam c's Avatar
Cheap Bastard
Old Jan 13, 2007 | 01:29 PM
Speed of light's Avatar
Form follows function
I love it! Exactly the fix I would do! I now have the other clutch switch (interlock) going out....we'll see if it works there.
Old Jun 10, 2008 | 02:50 AM
Azcamel's Avatar
Put it in her butt
your not cheap, you just use whats at hand.. now if you used duct tape to fix stuff then yoru cheap, but you actaully took time to take things apart and see if you can fix it, big thumbs up.
Old Jun 10, 2008 | 08:41 AM
hanman's Avatar
This thread is over two years old.
Old Jun 10, 2008 | 11:09 AM
Prophet7000's Avatar
VV That's mine VV
I'm surprised nobody brought up the MacGyver episode in which he fixed the throttle cable spring on an old truck with a spring from a ball point pen.
Oh and. . .. ZOMBIE THREAD!!!!
Old Jun 10, 2008 | 02:57 PM
YureiRX-7's Avatar
(^ _ ^)
Now selling clutch switch reman parts!!
Old Jun 10, 2008 | 06:45 PM
HawaiianRedMako's Avatar
Great, nothing like pure innovation from off-the-shelf parts. Saves money, I'll remember this thread if my clutch switch ever does go south.
Many thanks for the idea!
Old Jun 10, 2008 | 09:05 PM
trickshot's Avatar
In these troubled times it's good to know there are cheap bastard fixes and cheap bastards willing to do them.
Old Jun 11, 2008 | 01:58 AM
Tom93R1's Avatar
gross polluter
I found this thread over a year ago and did the fix, still going strong!
