Water injection!
Old Dec 28, 2005 | 11:52 AM
theagavejazz's Avatar
Water injection!
Which vaccuum line(s) do I need to use on an S5 NA to do the "water trick"? I want to do this, I heard it's really good but I don't want to mess anything up. Pictures would be helpful. Thanks.
Old Dec 28, 2005 | 12:41 PM
classicauto's Avatar
Crash Auto?Fix Auto.
are you reffering to sucking water into the motor thus somewhat steamcleaning your internals?
or actual water injection as the title states?
if its the first - doesn't really matter which vac line...I would use one that goes directly into the manifold as oppose to one that leads through a series of check valves and other lines before getting to the manifold.
EDIT: - why do you want to do this in the first place...if the car runs good and has no real issues then why bother pouring water into motor becuase you "heard" its good....???
Old Dec 28, 2005 | 12:44 PM
J-Rat's Avatar
Alcohol Fueled!
This is just a trick people use to steam clean the motor. I try to use a vac line that feeds both rotors.
Old Dec 28, 2005 | 12:51 PM
Icemark's Avatar
I use the middle vac line on the rear of the throttle body where the throttle body meets the DEI manifold on non turbos.
And the top feed from the PCV valve for Turbos.
The water trick should not be confused with water injection at all. Two entirly different things.
Old Dec 28, 2005 | 12:56 PM
J-Rat's Avatar
Alcohol Fueled!
Yep, and water injection should be ditched in favor of alcohol injection...
Old Dec 28, 2005 | 06:34 PM
Sorry for misusing the term, I got it from Kevin Landers' page. Thanks for the input.
DEI? this is for S5 right?
Old Dec 28, 2005 | 07:40 PM
NZConvertible's Avatar
I'm a boost creep...
DEI = Dynamic Effect Intake manifold, fitted to S4's
VDI = Variable Dynamic effect Intake manifold, fitted to S5's
If you do this you need to use a nipple that is fed from behind the throttles so it sees vacuum but close to the TB so both rotors are fed water.
Old Dec 29, 2005 | 05:00 PM
gaskibba's Avatar
When you do it keep an eye on your cat conv it can get pretty hot from the amount of gas being passed thru the engine unburned when doing this. Know from exp I barely caught mine in time, it lit some oil on the bottom of car. Now I'm just waiting to see how much smoke smell stays after letting it air for awhile.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
