Knock Sensor
Old Jan 29, 2002 | 07:54 PM
efiniracing's Avatar
Knock Sensor
Where is the knock sensor on an FD, and how can I relocate it?
Old Jan 29, 2002 | 08:16 PM
kevinmfaust's Avatar
The knock sensor is directly above the spark plugs. I think it is the # 1 rotor. I think they put where it is to be as close to the combustion chamber as possable. Moving it from where it is may make it less effective.
Kevin
Old Jan 29, 2002 | 09:14 PM
RexTech's Avatar
That´s right, it is above the rotor 1 -front rotor- spark plugs. Why should you move it?
You can find another free hole for another knock sensor in the rotor 2 housing.
I use the rotor 2 hole to screw my J&$ knock sensor.
Old Jan 29, 2002 | 09:37 PM
I want to remove it because it is overly sensitive. under high boost it is giving the ecu a high knock reading and the car goes into limp mode.
Old Jan 30, 2002 | 11:11 AM
How do you know it is too sensative. Knock starts out inaudable to the human ear. I was a Saab teck when they came out with there APC system. It was the first system with a knock sensor and I remember reading a teck artical they sent. The artical said that pre detination starts way before we can hear it with the ear. I dont know if there is a test for the sensor to. be carefull.
Kevin
Old Jan 30, 2002 | 09:52 PM
Well I talked to Peter Farrall about my problem, which is what appears to be fuel cut when I go over 13lbs of boost for more than a few seconds. This is a common problem w/ the EFI PMS. he explained to me that he had the same problem w/ his cars and after doing some testing when he relocated the knock sensor to a more distant area the problem was fixed. He says that what I'm getting is not a fuel cut but limp mode from high knock reading. I'm not sure if I believe him or not but I figured it's worth a try. Any thoughts?
Old Jan 30, 2002 | 10:29 PM
I dont understand what pms is, but my thought is that at 13 pounds of boost there should be enough fuel there even with the stock fuel system. If you have a upgraded ECU they should have advancd the timing to take care of the perdetonation that would come from higher boost. I run 13 pounds in my car with an M2 reprogram and I talked to the Pettet guys also and they said I could run 14.5 pounds with there reprogramed box. Relocating the knock sensor so that the box will work seems kinda over the top. It may be normal for this box, I dont know. I think I would call Pettit or M2 and ask them about it. I wish I could be more help.
Kevin
Old Jan 31, 2002 | 11:58 PM
I talked to some other guys today that are using the EFI computer and they said relocating the Knock sensor to the rear rotor might help. If I'm gonna mess w/ that should I go ahead and get a new knock sensor as well?
rgordon1979
40
Mar 15, 2022 12:04 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
83revival
Sep 3, 2015 10:42 PM
