So I lost all my oil 2night ??
Old Dec 27, 2005 | 11:22 PM
DriftingB26RX7's Avatar
Porsche-Hunter
when leaving my g/f's house i noitced a spot of oil under my car..i went to get gas and i opened my hood and the hole left front was covered in oil there was a huge spot on the floor. I'm thinking a oil cooler line burst. My oil press stayed within spec but what do you guys thing ???? please help me
Old Dec 27, 2005 | 11:51 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
1) how long was the drive to the gas station
2) how much oil is left in your engine? that means check the dipstick
3) check the oil cooler lines. replace if necessary
4) stock oil pressure gauge? doesnt really matter but they're known to not be reliable
5) after you fix the lines drive the car if no smoke then basically dont worry about it
Old Dec 27, 2005 | 11:54 PM
red87tll's Avatar
needs a cheaper hobby
^^^^yeah?
Old Dec 28, 2005 | 12:06 AM
KeloidJonesJr.'s Avatar
strictly business
It happens. Just filler up again. Could be oil drain plug.
Old Dec 28, 2005 | 12:21 AM
boost_its_what_for_dinner's Avatar
RotoriousRx7
looks like the omp line popped
Old Dec 28, 2005 | 01:17 AM
Porsche-Hunter
no my stock one works cuz i did a test at school with a cal. gauge. I had enough oil to drive home which was about 10 mins, the buzzer came on when i was 3 blocks away ONLY when i would make hard turns!!! I'm gonna check it in the morring. I put plastic down where i parked so i know its all gonna be gone. so well see 2morrow morring
Old Dec 28, 2005 | 01:20 AM
RotaryEvolution's Avatar
Sharp Claws
happened to me, luckily i was pulling the car into the shop as the line burst and i didn't even realize i left 5 quarts of oil on the road all around the block, you can lose oil VERY quickly when those lines burst and they are a weak point in the oiling system which is why i upgraded to some 3000psi+ tested line.
fix or replace the lines and fill it up, only then will you know if it caused damage or not.
Old Dec 28, 2005 | 01:28 AM
powrdby13B's Avatar
i'll blow YOUR valve off
and maybe be a little careful when you start it.. you get about 30 seconds before the engine seizes if you run without oil.. not that i would know.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
