Fabrication of OMP linkage after s4->s5 UIM swap
Old Dec 27, 2005 | 11:35 AM
buzz2's Avatar
When I replaced the S4 intake on my 87 NA with an S5 intake several years ago, I bent the old S4 linkage to work. It binds up a bit and makes the opening of the throttle plates a little jerky.
At the time I really didn't want to go premix. I still don't. Has anyone successfully rigged up a cable mechanism for this or has anyone had success bending the linkage and kept a smooth action?
Old Dec 27, 2005 | 11:59 AM
Icemark's Avatar
I just bent the top of the S4 rod...
Here is how I did it; the bottom of the rod (virtually everything you can't see) stayed exactly the same, with only the top part bent.
what semed to work best was actually bending it while it was attached to the MOP.
And yes it will take multiple bends and trys to find a good location that does not bind.
I guess you could use a cable, but the draw back is that you would have to fabricate a method of holding the cable at each end.
Old Dec 27, 2005 | 12:34 PM
kungfuroy's Avatar
Chicken Adobo
I am planning on doing the manifold swap myself but without the rod. I planned on using one of the many throttle cable kits out on the market. There shouldnt but much to it but cutting the cabel to length and the endlocks to keep it in place. Using the cable tube should keep the cable from chaffing on anything. Also use thread lock on the setscrews of the endlocks. I have had one of them back out on a gokart
Old Dec 28, 2005 | 06:11 AM
buzz2's Avatar
Did you cut off the end at the top?
Old Dec 28, 2005 | 07:48 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
i used a coat hangar once. worked flawlwssly for 30k+ miles.
Old Dec 28, 2005 | 12:12 PM
buzz2's Avatar
IceMark,
Can you take a closer picture of the bends at the TB and an overhead shot too?
Old Dec 28, 2005 | 12:36 PM
Icemark's Avatar
yeah, those are old pictures...let me see if I can get you some better shots, and I did not cut or change the length.
ZacMan
Sep 19, 2015 09:20 PM
rotor_veux
Sep 3, 2015 07:10 PM
