coolent leak
Old Dec 24, 2005 | 12:43 PM
tekwiz99's Avatar
fire in a hole
coolent leak
i suspect front rotor water passage is leaking, is rebuild necessary?
here are the pics:
digital zoomed (don't ever trust this again, unless i have to)
Old Dec 24, 2005 | 01:06 PM
kungfuroy's Avatar
Chicken Adobo
Front what I can see, that is where the water pump housing mates up with the front plate. If the leake is coming from there, you dont have to do a rebuild. Just remove the water pump housing, clean up the surfaces and look for anything odd like cracks and such. then use a NEW gasket and hi temp silicone to put it back together. Make a sandwhich liek below and check again for leaks
waterpump housing|silicone|gasket|silicone|front plate
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
