difference between 87-88 and 89-91 turbo?
Old Jan 29, 2002 | 10:46 AM
hondah8er's Avatar
mazdaspeed 3 coming soon
Smile difference between 87-88 and 89-91 turbo?
Can someone tell me exactly what is the difference between the 87-88 turbo and the 89-91 unit? And how do i tell the difference visually?
Thanks
Old Jan 29, 2002 | 11:17 AM
95R2-89TII Ground Zero's Avatar
Banned
I don't think that there is a way to tell visually. But if I remember correctly...the blades in the turbo were trimmed and the compression was changed. But hell, I can't remember.
Old Jan 29, 2002 | 01:15 PM
Greg's Avatar
89-91 T2s have higher compression rotors. Stronger dowl areas. Also there is marking on the bottom of the rotorhousings with a letter in a circle. The newer rotorhousings have I think a z and something else in them. Thats the visual difference . Ill go look at my rotorhousings later and let you know what leters should be on it.
Old Jan 29, 2002 | 04:30 PM
Toadman's Avatar
Nomad Mod
I believe the 90-91 turbos had 220hp, 20 more than the 88-89.
Old Jan 29, 2002 | 04:54 PM
TwinCam13BT's Avatar
The newer turbo will have a rounder turbine housing. The 87-88 is flater.
Like this.... U
Old Feb 4, 2002 | 07:45 PM
turboedRX-7's Avatar
The 87-89 T2's had 182 HP, while the heavier 89.5 + were 200 HP...Times in 1/4 mile were about the same...visually the 89.5;s had a cooler front air dam and 3 circle tail lights and the interiors were also different with 7 & 8K RPM redlines...Take your pick, their both great true sports cars!
Old Feb 4, 2002 | 09:38 PM
Talking about the turbo itself. Not the turbo model FC
Old Feb 5, 2002 | 02:16 AM
fastrotaries's Avatar
W. TX chirpin Monkey
The wastegate on the later 89+ is bigger and the exhaust manifold is at a 90 degree angle to the exhaust ports giving the gas a more direct approach to the turbine. It is simply a better design.
Queppa
Nov 18, 2024 03:47 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
