stereo/audio tech. geeks i got a question... can i do this??
Old Dec 16, 2005 | 01:34 PM
matts86fc3s's Avatar
southern style
alright i have 2 amps. 1 amp for all my speakers and 1 for my sub. its a crappy american legacy 400 watt and they both work good. but i hate constantly taking everything apart to turn the bass up and down (of just the sub) and i have freinds with little ***** they can turn to control the bass. only problem is my amp doesnt have a plug in or anything for one. i dont want to get a new amp. question is i just bought a new electric fan for the computer and it came with a **** to adjust the speed... (generic **** it would work for audio or anything else) yknow.. it goes from (min.) to (max.) how can i wire it up to my sub so i could controll the bass? like would i tap the power wire of the switch into the remote wire going to the sub to limit the volts going to it therefore limiting output of the amp/sub. or a different wire? what should i do ?(and before you say just turn it down with the head unit... i cant, it will lower the bass of everything, speakers included)
Old Dec 16, 2005 | 02:53 PM
AustinCustoms's Avatar
The only way the **** could work is if you cut the gain controll **** off the amp, and wire the new **** where the old one was. This can be tricky though, so I wouldn't recomend doing it.
Old Dec 16, 2005 | 05:06 PM
Hyperite's Avatar
Vagina Junction
You don't want to limit the voltage to the amp, otherwise it can clip and damage both the amp and sub. You want an RCA volume control ****. They've got 'em at harware stores and audio specialty stores and maybe Radio Shack.
Old Dec 17, 2005 | 11:09 PM
southern style
how would you hook it up tho, if my amp doesnt have a port/wiring for it?
Old Dec 18, 2005 | 08:12 AM
sonix7's Avatar
sorry but its your amplifier. you need one that has variable gain control. You have to turn the gain down on the sub not anything else. Sounds like you want an amp that does this not the amp you have. In stereo equipment, quality is extremely important. RCA line levelers will just turn down sound overall, not just bass. Now you could solve your problem by adding an in dash variable crossover. Then you can control every aspect of the sound spectrum and tune down the bass. goodluck
Old Dec 18, 2005 | 10:10 PM
Hyperite's Avatar
Vagina Junction
So? He has one amp for the bass....put the gain controller in line with the RCA plugs to that amp and badda bing...bass control
Old Dec 18, 2005 | 11:52 PM
sonix7's Avatar
my bad I read that wrong, yeah if you have a single amp dedicated to the woofer(s) then just lower the gain on the amp. thanx Hyperite for correcting me.
Old Dec 19, 2005 | 10:11 AM
Rob XX 7's Avatar
FC guy
he wants to be able to adjust the bass whille he drives, im sure he knows he can adjust the gain on the amp.
For the price get a new head unit that has sub control on it
freddyrx3
Rotary Drag Racing
31
Mar 9, 2019 08:32 PM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
demetlaw
Oct 2, 2015 06:22 PM
RedBaronII
Sep 20, 2015 11:29 AM
elfking
Aug 19, 2015 09:48 PM
