How do you clean up a J-spec block, Suggestions?
Old Dec 14, 2005 | 01:52 AM
TurboVert7's Avatar
i Just recently installed my Jspec tII engine what is the best way to bring it back to shine ? it has alot of corrosion
Old Dec 14, 2005 | 06:39 AM
Ottoman's Avatar
always modding
well for starters u should cleaned it before putting it in :P
dirt and oil usual chemical products work..
but it's corrosion.. u need good ol' elbow grease..
u gotta sand it all off...
then consider painting it
Old Dec 14, 2005 | 07:49 AM
pugg57's Avatar
proper motoring
i would suggest using the same method you would us to clean an OEM (or US spec) block... maybe squint your eyes a little more...
shoulda cleaned it before you put it in. corrosion needs sanding in one form or another to get it off
Old Dec 14, 2005 | 09:00 AM
John64's Avatar
What?
Don't they make special JSPEC engine cleaners?
Castrol degresser and alot of elbow greese!
Old Dec 21, 2005 | 06:30 PM
classicauto's Avatar
Crash Auto?Fix Auto.
or you could quite simply tug the motor.....pull it apart.....send the housings and irons for soda or bead blasting (on the outer surfaces only) bridgeport it and put it back in the car
or close your hood and cut the release cable
13
Jan 9, 2018 11:19 AM
