Power FC best 3 bar map sensor to use??
Old Dec 13, 2005 | 10:27 PM
adictd2b00st's Avatar
boost > *
ok i know alot of people are running the gm 3 bar map sensor, and the apexi one is hard to come by, will others work too? like what about the AEM one? wondering whats been the best in all your personal experiences, i need to pick one this month, thanks
Old Dec 13, 2005 | 10:45 PM
LUPE's Avatar
Get the GM, most people use that. I just sold mine in favor of a 4 bar.
Old Dec 14, 2005 | 02:39 AM
Jay7 Nyc's Avatar
rx7.com can get you the apexi 3bar sensor for about $200 they have one in stock now I called yesterday 12/13/05. I'm going to pick one up locally at rpmnyc.com for alil less then $200..
Old Dec 15, 2005 | 08:30 PM
the_glass_man's Avatar
Will u do me a kindness?
Get the MSD one for $50.
Old Dec 16, 2005 | 01:33 AM
boost > *
is this what your running? anything special to get it to work? or just wire it in the same way as a gm one?
Old Dec 17, 2005 | 12:24 AM
cmartinp28's Avatar
it is a GM one, and i have one for sale if you need it
what happenned to your other GM sensor?
Old Dec 17, 2005 | 01:05 AM
DCrosby's Avatar
No it's not Turbo'd
3Bar Gm Sensor for $200.00 wow I need to get into that business.... as I recall I bought mine off a Dealership's GM Parts Dept. and felt raped at seventy (7X.XX) some odd dollars...
Go to a GM dealer and ask for the boost sensor that came off a 93 Typhoon, I think was the year, it's like a Jimmy with Turbo.... they only made it for 1-2 years, and there was no other boost sensor on those .... also Grand Nationals had them I think....
Most Online GM parts dept.'s have parts lookups where you can see what cars that part fit too....
-DC
Old Dec 17, 2005 | 09:03 AM
Trevor's Avatar
Syclones and Typhoons had a 2-bar.
AFAIK 89 Turbo Trans Am's (GN motor) are the only GM car with the 3-Bar.
Old Dec 17, 2005 | 09:37 AM
LUPE's Avatar
-DC
Man, my local GM parts dealer charged my $130 for my old Map sensor
Old Dec 17, 2005 | 01:49 PM
Jay7 Nyc's Avatar
$140-$160 for the apexi plug n play 3bar sensor no splicing needed..
Old Dec 17, 2005 | 03:37 PM
boost > *
mind sharing where from? cause if thats true then i'll pick one of those up. i've been told $200+ for one.
Old Dec 17, 2005 | 04:23 PM
Jay7 Nyc's Avatar
rpmnyc.com gets them for $160.. Ramy may be able to get you one alil cheaper dont know would have to see if he will chime in..
Old Dec 17, 2005 | 06:12 PM
FDNewbie's Avatar
Sponsor
Hey Jay Yea, I can beat $160 on the Apexi 3-bar map sensor. PM me if you're interested.
Thanks
~Ramy
Old Dec 19, 2005 | 11:10 AM
DCrosby's Avatar
No it's not Turbo'd
Dunno, maybe they sell **** in florida cheaper or else it's been a while... I just remember paying less than $100..... Wow, inflation Sucks
Old Dec 20, 2005 | 11:45 PM
boost > *
thanks for the input guys, and big props to Ramy!
Old Dec 21, 2005 | 11:25 AM
RotorJoe's Avatar
Hooray For Boobies!!!
Does anyone know about the Denso 3 bar map sensor? I think I 've heard that it came from a supra? I'm not sure though, just seen someone using one and that's what they said it was out of.
Thanks
Old Dec 21, 2005 | 01:18 PM
RotorJoe's Avatar
After a small search I think the Denso Map Sensor is the ApexI Map Sensor?
Does it plug right in with out cut and splicing?
Thanks
Old Dec 22, 2005 | 07:58 AM
Jay7 Nyc's Avatar
Denso makes the stock map sensor for FDs. I havent recieved my apexi 3bar sensor as of yet but when I do i'll take pics. I know the apexi 3bar is a plug n play unit unlike the GM 3bar sensors..
Old May 29, 2007 | 01:04 AM
NoMorePoison's Avatar
Paper mache seals
So back from the dead that it makes me sick, but I found a denso 3bar from a guy in town for $25, and I want to know if it will work with the pfc.
Old May 29, 2007 | 02:45 PM
cewrx7r1's Avatar
Eye In The Sky
Any will work, but you will have to calibrate it to have the correct scale and offset if yoy want to have displayed boost and ABS PIM pressures.
Old May 30, 2007 | 02:10 PM
RX7LINK's Avatar
RX7FD3S
the Apexi 3 bar map sensor use the Denso one. so it should have the same plug as ur stock one.. just slightly different shape than ur stock.
I'm running the apexi /denso 3 bar. its been working fine. But unless you're boosting over 15 psi, there's really no need to get a 3 bar.
mulcryant
Sep 9, 2015 05:24 PM
befarrer
Sep 4, 2015 08:26 PM
