how fast is this setup?
Old Dec 12, 2005 | 10:20 PM
ProjectRE's Avatar
don't know how much hp yet, but boost at 7.5psi,
I smoke a SRT-4 at the light 3 to4 car lanes
what do u guy think how much hp and how fast 1/4mile?
I will soon run 14 psi
Major Upgrades:
Street Port 1 By Mazda B&B Racing
with rx7 year 91 rotors
Brake Upgrades:
Front/Rear Hawk
Drivetrain / Transmission:
EXEDY CLUTCH RACING STAGES 1 #10803A
Exedy Flywheel # ZF01
Electronics:
HKS Fuel Cut Control
HKS turbo timer
Turbo timer harness
APEXI SAFC II
APEXI AVCR Boost control
HKS Boost gauge 45mm
Engine Components:
MAZDASPEED oil lines
Koyo Radiator
Radiator E-fan
Vacuum Hoses Upgrade Kit
Throttle body mods
Exhaust:
GP SPORTS EXAS Spec II
HKS down pipe
Custom test pipe
TurboII Block off plates
Ignition:
NGK Spark Plugs
NGK Spark Plugs Wires
Intake:
HKS High Flow Intake
Strut Bars:
MAZDASPEED Front Strut Tower Bar
Interior/Exterior Modifications
Seats: Stock TurboII Seats
Tires:
Toyo T1S 205/50/16
Wheels: MAXX rims 16/7
Old Dec 15, 2005 | 09:28 AM
jkimbro's Avatar
resU deretsigeR
Fuel? I can say it'll go boom rather fast without fuel.
Old Dec 15, 2005 | 10:50 AM
bigdv519's Avatar
IFO Forced Induction Slo
~185rwhp, 14.5 quarter
Note: Stock Turbo, Stock Intercooler, no weight reduction.
You can run 15psi...but you gotta get a new motor after that.
Old Dec 16, 2005 | 05:54 AM
Cosmo_TT's Avatar
BRAAAAAP pssh BRAAAAAP
basically intake and exhaust and e-fan the to make more power you need fuel pump and injectors but i would guess around a 13.8 depending on driving skill
Old Dec 17, 2005 | 03:28 PM
RotaryEvolution's Avatar
Sharp Claws
the SAFC2 is fine for his current boost levels but to run 10-13psi(don't push higher than 13psi on the stock turbo) he would need an upgraded fuel pump and tuning with the SAFC.
i would say it would run around a 14 second or above with those mods, no way it'll run a 13.5.
Old Dec 17, 2005 | 06:10 PM
J-Rat's Avatar
Alcohol Fueled!
All Stock
88 MAZDA RX7 TII
Reaction .362
I1 2.317
I2 6.253
I3 9.566
MPH (I3) 74.573
E.T 14.856
MPH 93.25
Better work on that launch!
Old Dec 18, 2005 | 04:07 AM
sleeperfc's Avatar
MP T-70 = Fun
how is it all stock if it has all those mods?
Old Dec 18, 2005 | 06:36 AM
CyborgRyu's Avatar
Drift FC
stock runs 15.1?
more fuel pump/bigger rear injectors, you should see high 13s
Old Dec 18, 2005 | 07:05 AM
Cosmo_TT's Avatar
i said 13.8 punk not 13.5 lol well get it to the track so we can know for sure
we could tell you it will run a 12.9 but it doesnt mean that YOU will
Old Dec 18, 2005 | 05:12 PM
jacobcartmill's Avatar
just dont care.
i'm not sure why he needs an efan to get into the 13's????
Old Dec 18, 2005 | 10:41 PM
sleeperfc's Avatar
MP T-70 = Fun
maybe its because his s4 alt only puts out 70amps and he wants to kill it and his battery, then he can... ohh wait.
Old Dec 19, 2005 | 01:07 AM
Cosmo_TT's Avatar
i never said he needs one, i was stating that it is one of the mods done to his car
cause intake exhaust and an efan all free up power or give power however you look at it
the other mods he has are mostly just supporting mods
thats all i was saying
not that ooohhhhh if you have an efan you are in the 13's or you cant hit 13's without it
Old Dec 19, 2005 | 03:09 PM
ProjectRE's Avatar
that was stock setup
Old Dec 19, 2005 | 03:15 PM
ProjectRE's Avatar
well see whatsup, but the track are close, where can i go run?
Old Dec 20, 2005 | 01:33 AM
Cough XAS
An efan at this point really isnt that necessary. Though it doesnt matter it will help with cooling.
Whenever you start modding out an rx7 fuel is the most important thing to look at.
Old Dec 20, 2005 | 08:36 AM
ProjectRE's Avatar
people i do have e-fan install look up!
Old Dec 20, 2005 | 12:12 PM
Cosmo_TT's Avatar
i know you do
its just funny that people will consider pulleys or removing p/s or a/c a mod but a heavy fan that the crank has to turn and is creating drag on the motor is not a mod when removed
any weight that is removed from the cranks rotating mass is a mod it makes it easier to turn so yes it is a mod
just like a flywheel and pulleys and lighter rims it all makes things easier to turn
Old Dec 20, 2005 | 02:41 PM
Sharp Claws
it isn't considered a mod because though it is removing rotating mass and drag it is replaced by extra drag from the alternator which is compensating by recharging the battery from the extra electrical load.
there is hardly a noticable power gain from an e-fan and it is less reliable. i only tell people to use e-fans who have space issues with aftermarket radiators or relocated ones. in fact the stock alternator cannot handle the load for some e-fans and will draw the battery down quickly.
Old Dec 20, 2005 | 06:06 PM
Cosmo_TT's Avatar
i honestly think that the drag from the stock fan is more than the extra drag of the alt.
and i forget where i seen it but some shop showed an increase in horsepower by switching to an efan
Old Dec 20, 2005 | 06:44 PM
Xbladr's Avatar
I am sure an efan has its benefits but unless he has a massive fmic and a big turbo upgrade an efan is completely unnecessary... I know he has it already so that is no matter... but if he picks up some 720cc secondaries and tunes them with the safc on 11 psi or so he could very well break into 13's
Old Dec 20, 2005 | 09:46 PM
ProjectRE's Avatar
ok
Old Dec 21, 2005 | 05:40 AM
Cosmo_TT's Avatar
oh no doubt he can easily run 13's
Old Dec 21, 2005 | 05:49 AM
just dont care.
its fast dude. its real fast.
Old Dec 21, 2005 | 12:49 PM
sleeperfc's Avatar
MP T-70 = Fun
id say is about: E.T 14.856 @ MPH 93.253
Old Dec 21, 2005 | 09:12 PM
ProjectRE's Avatar
dude 14.8 was when the car was stock
