Oil Return Line Question.
Old Jan 28, 2002 | 10:37 AM
Gimpdiggity's Avatar
Question Oil Return Line Question.
Alright, it was dark out last night, but we finally found the oil leak that we noticed yesterday. It's coming from the return lines up by the radiator.
Here is my question, it was dark and a little cool last night, so we didn't spend alot of time looking at it. Are the oil return lines rubber lines?? If they are, what size are they, and how long are they?? The guy at AutoZone told me he thought they were rubber, but he wanted me to check first. I just figured I'd ask here and if I can get an answer, I'll buy the lines from AutoZone on my way home from work, and install them tonight and save myself a trip!!
Thanks,
Jeff
Old Jan 28, 2002 | 11:58 AM
::bump::
Old Jan 28, 2002 | 12:35 PM
cymfc3s's Avatar
I Raise Chickens
need more info man. Are you talking about the oil metering lines??turbo oil return line?? Is your car NA, turbo?
Old Jan 28, 2002 | 12:40 PM
It's an N/A.
As far as I can tell, they're the lines that transfer the oil to the oil cooler, up near the radiator.
Thanks,
Jeff
Old Jan 28, 2002 | 12:51 PM
cymfc3s's Avatar
I Raise Chickens
Ok, its the oi cooler lines. You *can* rig it with high pressure oil hose, but i HIGHLY recommend you either get the factory oil cooler lines or the racing bear SS lines. Its not an easy job to change, but very very important. One of those lines suddenly goes and all your oil will dump out in a hurry. Then instead of spending a couple hundred bucks, your looking at a couple thousand.
Old Jan 28, 2002 | 12:53 PM
So, you think that high pressure oil hose will get me by for a few days at least?? I don't drive the car much, yesterday was the first I'd had it out in at least 2 months. Is there anything else that you think could be leaking?? We saw the leak coming from one of those hoses, but there seemed to be ALOT of oil down under the car.
Thanks,
Jeff
Old Jan 28, 2002 | 12:55 PM
cymfc3s's Avatar
I Raise Chickens
Thanks,
Jeff
Heres the basic leak check diagnosis. Get a can of parts cleaner. Clean the hell out of the area with all the oil is its nice and clean. Go rip around and look to see where the oil is coming from.
andyvideopro
Aug 20, 2015 10:55 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
