Good idea for more HP
Old Jan 27, 2002 | 11:13 PM
DC350's Avatar
Rotor Head
Once you have your n/a 87...take out the Cats....take off the air pump...take out that phat *** fan and get a couple of electric fans...it sure frees up alot of power! it's great to less belts what do YOu think
Old Jan 27, 2002 | 11:18 PM
J-Rat's Avatar
Alcohol Fueled!
I think thats a ****** GREAT idea, unless you have to pass emissions.....
Rat
Old Jan 27, 2002 | 11:21 PM
amemiya's Avatar
yeah but make sure you buy a high cfm fan the regular parts store fans wont cut it. get a flex-o-lite or something that will fly. Remember overheat it and it's gone, so this a touchy area proseed with caution.
Old Jan 27, 2002 | 11:23 PM
DC350's Avatar
Rotor Head
hey
so...you reccomend a good aftermarket fan...yup if it over heats....uh o. what exactly happens if they overheat?
Old Jan 27, 2002 | 11:24 PM
J-Rat's Avatar
Alcohol Fueled!
The water seals go by-bye and you have to rebuild the motor...I am running a 12 blade electric on a switch...It seems to be working pretty good. Just dont forget to turn it on...
Old Jan 27, 2002 | 11:27 PM
DC350's Avatar
Rotor Head
this fan doesn't come on with the engine? or speed up with different idle speeds? and nope i dont have to pass emissions!
Old Jan 27, 2002 | 11:31 PM
amemiya's Avatar
if you overheat your engine it worps this is bad
put your fan on a relay from the ignition
Old Jan 27, 2002 | 11:32 PM
J-Rat's Avatar
Alcohol Fueled!
I dont know of any electric fan that changes with idle speeds...YOu can get a kit that has a temperature probe so the fan comes on at a certain temp.. I just like the control of the switch. I can turn off the fan to get to operating temp faster. Man, I really hate you people that dont have to deal with emissions testing.,....
Old Jan 27, 2002 | 11:40 PM
DC350's Avatar
Rotor Head
hehe
yeah dude, it's great so much more fun....so much easier...soo just hook up the fan to the 1 ignition wires in the ignition harness?
Old Jan 27, 2002 | 11:41 PM
DC350's Avatar
Rotor Head
also askin about....switches...can you get switches that you hook up 1 wire....then out the other side of the switch and it will work as a toggle?
Old Jan 27, 2002 | 11:49 PM
amemiya's Avatar
Re: hehe
TRUST ME USE A RELAY
Old Jan 27, 2002 | 11:51 PM
J-Rat's Avatar
Alcohol Fueled!
switches..
The problem with electric fans is that they draw ALOT of amperage. 40 Amps or more. If you want to run a switch as a toggle, with the main 12V for the fan going directly through the switch, you need a pretty hefty switch (or one rated at 40 amps). If you run a switch thats rated lower, you are risking a fire hazard. What I did, was install a heavy duty 12V relay on the battery box, then ran a switch into the car. The switch activates the relay, which turns on the fan. Its a bit more complicated as far as the whole wiring assembly goes (I am just lucky, its what I do for a living). But it is a safer way to go.
Old Jan 27, 2002 | 11:52 PM
J-Rat's Avatar
Alcohol Fueled!
If you need wiring diags, I can probably help you...But most relays have the wiring directions on them...And if you buy an aftermarket fan, it might even come with one.
Old Jan 27, 2002 | 11:55 PM
DC350's Avatar
Rotor Head
you can buy a better alternator...one rated at 200 amps... do electric fans over not cut the mustard and are not as good as the ones powered by the V-belts?
Old Jan 27, 2002 | 11:59 PM
J-Rat's Avatar
Alcohol Fueled!
Electric fans are fine...They actually give you less parasitic drag on the Crank. Good for a couple more horsies at the wheels and better throttle response. No need to change your alternator unless you are running tons of crap I.E. big booming stereo, extra lighting...Etc. You an also get an electric water pump. I havent messed with those so I can speak intelligently about them. Anything you can eliminate from the V-Belt system is going to improve your performance. But the gains arent going to be as signifigant as you may think...
Rat
Old Jan 28, 2002 | 12:06 AM
DC350's Avatar
Rotor Head
well, i guess i am messed...i need a new alternator.....i am going to have hella neons....nice stereo...and an electric fan...haha time for that nap
Old Jan 28, 2002 | 12:07 AM
J-Rat's Avatar
Alcohol Fueled!
Neon lights?
Whats with the neon lights!?!?!?!? You kids are wierd.....
Old Jan 28, 2002 | 12:19 AM
yea electric fan frees up some hp. get a thermostat with it. so u wont be being a rebuild kit
Old Jan 28, 2002 | 12:20 AM
J-Rat's Avatar
Alcohol Fueled!
What type thermostat? I am using the stock one..But I was contemplating a 160 deg...
Old Sep 29, 2003 | 03:53 AM
DC350's Avatar
Rotor Head
Thread from the dead. I can't belive i said i was goin to have hella neons. What was i thinking
Old Sep 29, 2003 | 04:00 AM
bingoboy's Avatar
Lava Surfer
you mean smoking.
Old Sep 29, 2003 | 04:08 AM
DC350's Avatar
Rotor Head
yeah... Smokin... Sounds like crack
Tannergsl-setarga7
Aug 19, 2015 08:55 AM
bURGRotary87
Aug 19, 2015 03:54 AM
rexhvn
Aug 19, 2015 02:59 AM
