View Poll Results: What part is broken most often??
Radio surround
137
26.97%
Electric antenna
206
40.55%
Idiot light surround
104
20.47%
Sun visors
28
5.51%
Sun roof
96
18.90%
Torn upolstry (yea i cant spell today)
106
20.87%
Door handle/s
89
17.52%
Center console
71
13.98%
Radio grilles
41
8.07%
other misc interior stuff
133
26.18%
Multiple Choice Poll. Voters: 508. You may not vote on this poll
Used 2nd gens, what part broken most often?
Old Jan 27, 2002 | 05:18 PM
Agent_D's Avatar
rawr
this is a poll for what is broken most often on used 2nd gens
here is my list,
on all 3 of the 2nd gens ive owned they have all had this broken:
all 3 had: 1 broken door handle, broken radio surround, broken radio antenna, broken console, missing demister grilles, idiot light surround, sun visors gone or broken.
what about you guys??
Old Jan 27, 2002 | 05:54 PM
FEDREX's Avatar
"Just Looking".......
I would add these:
power window switches
wiper switch
differential mounts
logicon
power window regulator
Old Jan 27, 2002 | 06:30 PM
supergoat's Avatar
Eggs are like fowl cheese
Anything that gets held in by screw breaks at the point the screw goes in I've noticed.
Old Jan 27, 2002 | 07:07 PM
Wankel7's Avatar
Haven't we ALL heard this
The part that breaks the most....the 2nd gen. Can the car be considered a part?
James
Old Jan 27, 2002 | 07:22 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
I would have added exhaust/6 ports to the poll...Max
Old Jan 27, 2002 | 08:16 PM
vaughnc's Avatar
knowledge junkie
Most of that stuff is what happens when you let your car bake in the summer heat. I'd invest in an rx7 carpet dash cover from Victoria british, a tint job, etc..
I'd say the #1 thing is the engine wiring harness managers (no big woop), paint above the exhaust pipe, hatch struts, power window linkage, etc..
Old Jan 27, 2002 | 08:23 PM
TonyTurboII's Avatar
Glock Lover
I got jipped, I only have 4 ports!!
Old Jan 27, 2002 | 08:55 PM
mazdaspeed7's Avatar
mad scientist
diff mount!!!
Other than that, the sail panels(triangle pieces on inside of where the side mirrors are.
Old Jan 27, 2002 | 09:03 PM
amemiya's Avatar
Originally posted by FEDREX
I would add these:
wiper switch
differential mounts
logicon
god damn you hit it right on the head
Old Jan 27, 2002 | 09:14 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
oooooooh oooooooooh i have one.
Pulsation Damper
oh and every piece of interior cept the dash
Old Jan 27, 2002 | 09:20 PM
mad scientist
Pulsation Damper
Wow, S5's are awesome...
Old Jan 27, 2002 | 09:56 PM
JerryLH3's Avatar
Rabbit hole specialist
You forgot wiper switch?!?!
That get's my vote, under other of course. Of course, my sun roof always needs a little bump to get it going...
Old Jan 27, 2002 | 09:59 PM
HuggyBear's Avatar
pasenger side motor mount......
Old Jan 27, 2002 | 10:19 PM
I think you guys are also missing a few more... my I have the one rx7 and between me and my friends we have had 10 rx7's.... And i think in every single one of them...
not one... had
a Working Horn
or
A Working Clock
we had to resolder that stuff...
Old Jan 27, 2002 | 11:29 PM
amemiya's Avatar
1.the screw copming out of the blinker lever.
2.wiper switch
3. passeger motor mount
4.wiper switch
5. map senser ground
6. horn
7.clock
8.sunruff
9.diff mount <---------god I have done that one to many times
10.logicon
11.shifter bushings
12.TPS <---------god I have done that one to many times
13.viser plastic pieces
BUT I still love them
Old Jan 28, 2002 | 07:06 AM
go_speed_go's Avatar
Wow, all these posts and no-one has these yet:
- Headlight switch and harness.
- Radiator (those resin tanks are time bombs)
Old Jan 28, 2002 | 07:58 AM
The Ace's Avatar
Greek Power
My vote goes to:..............
1) Wiper switch
2) Power antennae
3) Sun roof
4) Electronic Lock
hmmm....nothing else
Old Jan 28, 2002 | 12:30 PM
tmak26b's Avatar
I froze 3 4 piston front caliper
Old Jan 28, 2002 | 03:30 PM
SureShot's Avatar
Seduced by the DARK SIDE
All the switch mount posts on the inside of the dash cluster.
This kind of thing is normal for >10 year old cars.
By the way, I have a great fix – Bondo Marine Epoxy Putty Stick. You knead a small snake, wrap it around the post to beef it up. A whole new post tip can be formed with a short piece of tube (cut from a radio antenna) filled with epoxy putty. You mold the hole with a nail while it’s still soft.
You can reinforce any interior plastic with this stuff. Just mold a patch on the back side. If it breaks off later, rebond it with super glue..
Old May 26, 2002 | 05:28 PM
SilverT2's Avatar
My vote goes for:
The owners bank account.........
Old May 27, 2002 | 07:28 AM
The Ace's Avatar
Greek Power
Wowow, a thread from the grave, but it sure made me look back and realize how much I've replaced/spent on my Rex (in no particular order):
Power antennae
Clutch
Brakes
Door handles
Thermostat housing
Almost all rubber hoses in engine bay (kinda expected, but...)
Thermostat, O2 sensor, various caps and sensors
and I will need new oil lines and new rotors (just the rear ones, but I'll change them all with slotted anyway)
...and I still havent had the time to fix the wiper switch
Everything works fine now, hope it stays that way for a couple of months
Old May 27, 2002 | 10:15 AM
dre_2ooo's Avatar
WINDSHIELD WIPER switch!!
Old May 27, 2002 | 11:35 AM
downwinddave's Avatar
Wow, I still have something to look forward too!
I have most of those...
I'll add:
top will not close...91 Vert.
Old May 27, 2002 | 07:36 PM
E6KT2's Avatar
Hey, I've owned three (one was a parts car) and all three had no comp on rear rotor but I don't see that listed. How about making "rear apex seal" an option?
Old May 27, 2002 | 08:13 PM
HAILERS's Avatar
HAILERS
1. Wiper switch (or its internal relays actually)
2. Logicon
3. Clock/idiot light assy (cold solder joints)
4. CPU (controls horn, idiot lights etc) cold solder joints.
5, The circuitry in the heater/air conditoning mtr housing(causes low fan speed).
6. The differentials front mount (only a gun pointed to my head will get me to jack my car using this point).
7. The a/c relay located in front of the radiator.
8. Acv on turbos (the switching diaphram gets cooked making it non-funcitonal. N/a's last forever).
9. Turbo's sliding roof (learned early not to open it fully and how to press down on it to make it shut).
10. Shifter bushings. The turbo's shifter was a guessing game until I put two conical bushings out of two spare transmissions in it. Used two top conical bushings salvage from the spare transmissions. Shifts like a champ now. (gonna buy the real bushings....soon).
But kudos to the ECU and the pop-up head lights that have never given any sign of trouble, never ever.
