Haltech F10 cant connect
Old Nov 29, 2005 | 01:12 PM
skir2222's Avatar
I win
F10 cant connect
Hey guys hows it goin? My fc is at the shop right now tryin to get it fired with the new motor! We connected the laptop to the connector on the haltech and it wont communicate, the laptop is setup correctly and everything its just not communicating with the computer~!
Old Nov 29, 2005 | 01:21 PM
turbine's Avatar
check your fuses, powers and grounds.
then check to make shure your com port is enabled, if it is enabled you can disable it shut off your computer plug in the com port then start it up and see if your computer detects the new hardware
Old Nov 29, 2005 | 02:02 PM
skir2222's Avatar
I win
Everything is in check including the laptop
Old Nov 29, 2005 | 08:37 PM
purple82's Avatar
Absolute Power is Awesome
what operating system are you using?
Old Nov 30, 2005 | 12:49 PM
skir2222's Avatar
I win
windows 98 or 95 its a really old laptop if i get a chance to drive to the shop today im goin to try and delete the com ports and then restart it then boot it in does and try it again. He said everything is gettin power... the injectors and the ecu so it should work I dont see why not!!!
Old Dec 17, 2005 | 10:32 PM
TurboIIGuy's Avatar
Driveline Killer
hey so did this problem ever get resolved??
Sethix
Nov 3, 2017 11:48 PM
Captain Hook
13
Oct 4, 2015 06:35 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
pfsantos
Sep 30, 2015 01:29 PM
