Help a girl out...w/Auto Shift knob replacement
Old Nov 28, 2005 | 10:29 PM
FDNena's Avatar
I
Help a girl out...w/Auto Shift **** replacement
Let me start by saying I know you can do this, but I need to know how before I buy everything and take the car apart... (also before you gentlemen start I am not swapping to a manual) and yes I searched already for like an hour...
I need to also know how to take the stock shifter off.
I want to put an aftermarket **** on it. I have a pic of an auto FD with a Sparco shifter in it.
Thanks for the help.
Attached Thumbnails Help a girl out...w/Auto Shift knob replacement-ff-interior.jpg
Old Nov 28, 2005 | 10:48 PM
bajaman's Avatar
Constant threat
Well......this is news to me. I don't know how you'll incorporate the hold feature switch (front top button on the shifter) nor the shift-interlock (rear top button on the shifter)?
Old Nov 28, 2005 | 10:49 PM
DaleClark's Avatar
RX-7 Bad Ass
Page K-27 of the shop manual. There are 2 screws on the shifter, on the side closest to the radio. There is also a wire going up into it for the hold button - I think that has to be pulled through as well.
Any aftermarket auto tranny **** will probably not have a Hold button on it, BTW.
Dale
Old Nov 28, 2005 | 10:56 PM
misterstyx69's Avatar
Retired Moderator, RIP
I know that B and M makes an auto stick shift ****..if that is any help..
Old Nov 28, 2005 | 11:30 PM
AUM's Avatar
AUM
I am the Architect
You could probably use this shift **** that has an overdrive button that can most likely be used for the hold feature button. The size and shape of it though looks to be the similar to the stock **** if that is a concern.
Attached Thumbnails Help a girl out...w/Auto Shift knob replacement-413_b.jpg
Old Nov 29, 2005 | 08:58 AM
FDNena's Avatar
I
Thanks for the info on how to take apart Dale. I don't need the hold button since it does not work because I have a PFC installed on the car.
AUM thanks for the pic, too bad it is not too attractive looking....
I am looking to put a MOMO auto **** on it. My shift plate needs to be replaced badly and I have an extra boot off of a '96 so I think I will just use that one. I may need to cut the handle about 2" from what I have read.
I wish I could get the AT RX-8 **** to work but it does not have a button to unlock it like the RX-7. I was hoping someone knew how to do it without needing the button to shift it....?
File Type: bmp
Old Nov 29, 2005 | 09:14 AM
Nat6c's Avatar
Is the unlock button electronic or mechanical on the ****? if it's mechanical you'd need to find a way to hold whatever unlocks it in the open position.
Ie. friends auto civic had a metal stick that wne right up the middle of the shift lever. if you pushed it down it unlocked to change gear selection. we just glued it pushed down.
down fall is you gotta be careful b/c it will give you the ability to accidentaly knock the shifter into N or if it hard enough R. etc. if you take the **** off and snap a pix i can try to help you figure something out.
Los.
Old Jan 25, 2006 | 07:26 PM
FDNena's Avatar
I
Finally....Just thought I'd update this topic I posted in case someone searches and wants to know how it turned out.
I was able to replace the ebrake with this MOMO pit stop handle. (Quite a bit a work since the MOMO is a straight handle and my 93FD had a slight contour.) I love the look but should have gone with another handle.
As for the Auto shift ****. I love my new one! I have to re-iterate I do not use my hold button since I am running a PFC and it doesn't work anyways. What i found out was the **** I got is the same size as the shifter so I had to dremel the inside to slide it down. I only secured it to the top hole because I was afraid it would be too low if I went down to the second, but I may change it later.
Now I am just looking for a shift boot plate since I have a RHD one from a '96 that I have no use for.
Old Jan 25, 2006 | 07:29 PM
FDNena's Avatar
I
BTW - Anyone know where I can find a new button to match the ebrake?
Old Jan 25, 2006 | 07:32 PM
Snotcycle's Avatar
Furious Ass-Monkey
Question: why do you have two SWEETass cars in automatic.....
Old Jan 25, 2006 | 07:33 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
Cool... umm ughh, I think
Old Jan 25, 2006 | 07:59 PM
FDNena's Avatar
I
Because I can.... j/k Thanks for the compliment!
I find it is mainly 7 owners that hate on the auto's and some reasons are valid...but not it the Supra world. Actually almost all of the cars both my boyfriend and I have owned are auto's...in his stang did 8.52@168mph in the qtr mi. We have 5 cars right now all Auto's and all turbos!
As for the Supra it is a 10sec. car. And the 7 I don't know yet. It hasn't been to the track or dyno yet with the mods I did, but that is okay cause I don't mind just lookin cute in it!
Old Jan 25, 2006 | 08:05 PM
7racer's Avatar
you can buy a stock button for the ebrake that is chrome...
ugh...i think Dale posted it....I'll search for it in a bit
Old Jan 25, 2006 | 08:14 PM
FDNena's Avatar
I
I knew I had seen this somewhere I found his thread thanks!
Old Jan 25, 2006 | 08:33 PM
GoRacer's Avatar
Speed Mach Go Go Go
Razo makes a realy nice carbon fiber shifter for the auto. I don't like Momo's since those little set screws get loose from vibration.
Old Jan 25, 2006 | 08:35 PM
Taikutsu's Avatar
http://www.clubrx.org/default.asp?id...ntent=56&mnu=3
there you go...its just a miata ebrake button
Old Jan 25, 2006 | 09:13 PM
93silverbullet's Avatar
Living the dream...
Yeah.. I got one from Ray at Malloy's for about $6.00 (in chrome). Looks great!
Old Jan 26, 2006 | 09:17 AM
FDNena's Avatar
I
That is why it is good a use a bit of loc-tite on it. It shouldn't come loose once you use that on it. Also, I went with the MOMO cause the material seems to match my otherwise stock interior well.
Old Jan 26, 2006 | 11:02 AM
maduhbee's Avatar
Love me for my car
eww, silver interior! I had to replace mine because when i bought it, it came with the silver interior! I did not know it was that popular! heh, actually i think one of the better ones is the RX-8 5-speed shift **** (as far as aftermarket goes)
Old Jan 26, 2006 | 12:35 PM
FDNena's Avatar
I
I don't know what you are refering to but I don't have a silver interior? The **** is black leather with chrome button and 2 chrome rings is all. The rx8 is nice too but many folks already have it. As far as for the automatic it does not have a button to change the gears. So that is a no go for me, I don't think it is too smart to weld it in the down position.
Old Jan 26, 2006 | 01:42 PM
HDP's Avatar
HDP
I think he's/she's referring to the very first pic you posted showing the Sparco auto shifter.
rgordon1979
40
Mar 15, 2022 12:04 PM
Apoc3D
Sep 5, 2015 10:24 AM
