Please Help!!! How To Change Oil Pan, Got Lost... Help!!!!
Old Nov 28, 2005 | 07:10 PM
KiNGeKSTaCY's Avatar
Im trying to change my oil pan because i dented the one i had prior. Looks really confusing because i'm not sure whats holding up the engine. Do i take off the crossmember? Do i use a cherry picker to hold up the motor? Has anyone done this? please send me a link or guide me through this process, i would greatlly appreciate it.
Old Nov 28, 2005 | 07:17 PM
DaveW's Avatar
Racecar - Formula 2000
Try this thread:
https://www.rx7club.com/showthread.p...easier+oil+pan
I held up the engine with a home-made unit that rested on the edge of the engine compartment that the hood recesses into. I lifted on the lift bracket on the LF of the engine until the engine was as high as it could go (trans against the body).
Between that and the above link, that should get you started.
I haven't put in all of the details - hopefully you can figure it out from here. The shop manual is a great help - you can download it - there are links to it in the "stickies."
Search for "oil pan sealing" for more info.
Old Nov 28, 2005 | 09:06 PM
thank you
Thank you kindly for the info.
Old Nov 29, 2005 | 07:14 AM
DaveW's Avatar
You're welcome.
Old Nov 29, 2005 | 02:00 PM
dgeesaman's Avatar
Is your current oil pan badly dented or leaking? Because I wouldn't touch it if the dent is cosmetic. FD oil pans tend to leak enough that it's best left alone if there isn't a good reason to remove it.
Old Nov 29, 2005 | 03:53 PM
Xeros's Avatar
I'm sorry wha?
you knwo i wa sjust about to do this becasue i have an oil leak from the rear of the engine ever since it wa sinstalled, I'm abot to pull the tranny to replace the seond gear synchro becasu emien is trashed. I was going to go this route but it seemed liek too much of a hassel and i figured if the engine is all apart as is and the tranny is coming out might as well just pull the sucker out. By the way has anyone ever done an exhuast port on the engine whiel the engine was still assembled haha?
FD7KiD
15
Feb 26, 2021 10:12 PM
rocker1337
16
Sep 6, 2015 11:28 PM
FD7KiD
Aug 17, 2015 11:50 PM
