I have no sound
Old Jan 25, 2002 | 08:13 PM
kemozabi's Avatar
.....shhh hes coming.....
Exclamation I have no sound
I have no sound. my old deck was stolen out of my car but before that it all worked fine. but now after tryin to install another deck things arent goin the way they should. i have the antenna wired to the ground for now until i get my relay. That works, and the deck lights up but no sound comes out. i cant figure it out so someone plz help me. o ya and there are two wires that have nothin connected to them, they are both grey with a yellow stripe.
Old Jan 26, 2002 | 01:43 AM
Icemark's Avatar
what year or model?
Old Jan 26, 2002 | 02:12 PM
kemozabi's Avatar
86 n\a. it used to have the stock tape deck and the eq in it.
Old Jan 28, 2002 | 02:27 AM
kemozabi's Avatar
come on people work with me..........
Old Jan 28, 2002 | 10:36 AM
Icemark's Avatar
There are no grey/yellow there.
Perhaps you listed the wrong color???
Okay I'll post the radio wires again... Maybe somebody will do a search and find this next time.
LTBlue/Red= 12v+
LtBlue/White= +Accessory
LtBlue/Yellow= -power ant trigger
Red/Black=+ Lumination
White=Factory Amp Turn on
Ground to the body, use the 10mm bolt behind the center console front drivers access panel. Do not use the Red/Black as ground it will damage the interior light circuit and dimmer in the car
Front Speakers (maximum of a 15 watt peak from the radio):
LtGreen/Red= Left
LtGreen/Black= Left
LtGreen= Right
LtGreen/Yellow=Right
Rear Speakers (if applicable, if you have the amplified rear speakers again the Maximum of 15 watts peak is all the stock speaker amp input can handle):
Brown= Left rear
Brown/White= Left Rear
LtBlue= Right Rear
LtBlue/Orange=Right Rear
Old Jan 28, 2002 | 05:07 PM
kemozabi's Avatar
im pretty sure i have it all hooked up right.......but il give it another try before i shell out the bucks
Old Feb 2, 2002 | 09:11 PM
RLBRX7's Avatar
The wiring instructions above are correct. Some 1986 N/A's did not have any amplifiers under the speakers in the rear towers. If yours has none there will still be some wires with plugs on the end that would have gone into the amp. Don't use these wires for anything. The light blue series and the brown series are the wires to use for the rear speakers. These same wires must also be connected properly at the rear of the head unit.
Old Feb 3, 2002 | 02:44 AM
kemozabi's Avatar
ok.... let me try that out tomorrow, hopefully it will work. but shouldnt i have sound commin out the front speakers, or is there an amp there too that could be troublesome? thanks for the advice ima try it out
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
