Combustion at 40, whats normal?
Old Jan 25, 2002 | 08:04 PM
BlackShadowRx7's Avatar
and what could cause it to be so low?
thanks,
btw the starter works fine, norrowed down the turning over problem to the ignition switch, or saftly relay switch,
Old Jan 26, 2002 | 02:41 PM
BhamBill's Avatar
I'm assuming you mean compression. Should be up around 90-100. could be flooded or you could have a bigger problem. Try the ATF trick to see if it'll come back up.
Einheri
Oct 7, 2015 12:23 PM
binz
Oct 2, 2015 03:52 PM
93FD510
Oct 1, 2015 02:00 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
