post your EGT temp
Old Jan 25, 2002 | 07:06 PM
amemiya's Avatar
post your EGT temp
I run 1390 the EGT is 4 inches from turbo
Old Jan 25, 2002 | 08:14 PM
amemiya's Avatar
Re: post your EGT temp
no one has a EGT????
Old Jan 26, 2002 | 01:00 AM
lone wolf's Avatar
Mines at 700 and it's about 6" down from the downpipe at full boost and floored.
Old Jan 26, 2002 | 03:54 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Your egt gauge is lying to you, My car idols hotter than that at around 780'F...
My sensor is in the exaust housing of the turbo.. It also seems to like around 820-880'C or 1500-1600'F the best...
Old Jan 26, 2002 | 01:18 PM
lone wolf's Avatar
I have a Greddy EGT gauge and it takes measurement in Celsius. I forgot to mention that. I'm pretty sure it's right. The ideal temperature for being on the downpipe is 700'C and on the housing i think it was 900'C. You scared me for a moment there.
Old Jan 26, 2002 | 01:35 PM
Dragon's Avatar
ahhh, that sounds much better...
Old Jan 26, 2002 | 02:43 PM
soul assassin's Avatar
GTR eater
mine is also in
celsius reads a tad over 900 at full boost, the probe is located in the exh housing of the turbine
Old Jan 26, 2002 | 02:44 PM
setzep's Avatar
that's funny...the guy in Japan has a meter that reads in SAE and the guy in the USA has one that reads metric. Why don't we just switch over to the metric system, make things a lot easier.
Old Jan 26, 2002 | 03:20 PM
peejay's Avatar
Old [Sch|F]ool
'cos metric sucks, that's why
Old Jan 26, 2002 | 03:53 PM
JoeD's Avatar
no, the gay american system sucks. metric is much easier and just makes more sense than the american system.
Old Jan 26, 2002 | 04:13 PM
setzep's Avatar
I love it when people don't get the joke.
Old Jan 26, 2002 | 04:16 PM
peejay's Avatar
Old [Sch|F]ool
It's what you're used to. In the end it's all just numbers. (You did note the smiley right?) But, this thread for example... I'm used to EGTs being discussed in Fahrenheit - the people on a mailing-list I'm on talk about their EGTs being in the 1450-1550 range, and I've seen where ideal for a turbo rotary is 1650, but that doesn't take into account different porting, different ignition timing, different types of fuel, where exactly the probe is placed, how good the intercooler is, etc. etc. And then to throw the wrench into the works now I've got to mentally convert degC into degF so I can apply more knowledge to my mental database (which is calbirated in Fahrenheit), hence my mild frustration and snide little comment.
Also, in the US, it seems that all the companies that cater to the "rice market" calibrate their gauges in metric because it's different from standard (in the US remember).
FWIW - 700degC is 1292egF, 900degC is (let's see, 180degF for every 100degC, therefore...) 1652degF. Beauty.
Old Jan 26, 2002 | 09:01 PM
amemiya's Avatar
WHAT ARE YOU TALKIN ABOUT
sorry guys my falt I whould have specified..degF
we should switch to metric though " what is the next size up form 9/16???huh I think it is 5/8 huh I think so try it"
Old Jan 27, 2002 | 06:21 AM
Dragon's Avatar
Mines metric, I just converted to F for you USA guys... Metric is much better... Screw that SAE stuff...
Old Jan 27, 2002 | 11:55 AM
Gearhead's Avatar
Probe position in relation to the turbo (b4 or after) is going to make a good bit of difference due to the pressure difference b4 and after, and also due to the turbo absorbing some of the heat.
Old Jan 27, 2002 | 05:30 PM
amemiya's Avatar
ok people let stop trying to sound smart there are to many veriables to what makes the temp hire or lower lets just post ower temps and exaust placement...
sorry for any hostilaty
Old Jan 27, 2002 | 07:50 PM
peejay's Avatar
Old [Sch|F]ool
Well I dunno about that... it does make a difference where the EGT is mounted.
Would it be risking inaccuracy to put the probe after the turbo? I only ask because all of the commonly available gauges only go up to 1600degF (err, 875degC ) and all of the gauges that read higher (like soul assassin's) are imported and quite expensive, and usually white faced. That's kinda petty I know, but call it a personal preference for black-faced gauges. Anyway, if it's reasonably safe to take the temps after the turbo, that means I have many more options for gauges.
Old Jan 27, 2002 | 08:06 PM
GTR eater
yeah i like that gauge it is silver faced and lights up the same color as the stock interior lights
Old Jan 27, 2002 | 08:39 PM
amemiya's Avatar
yes since the temp gauged is made to take exaust temp on the dyno, then compare it when ever driving or tuning to try to mantain that temp, the placment is not to specific within reason. just remember changing something can alter the temp which would requirer you to redyno which you should anyway after just about any mod.
Old Jan 28, 2002 | 03:48 PM
surfpac's Avatar
I have a Westach EGT gauge purchased from Aircraftspruce.com for $80, including the probe. It goes up to 1700F and is black faced and the needle is white with a red tip. Also it is ergonomic in the sense that the needle never covers the number. Anyone ever wonder why do most gauges have the needle cover the numbers? Makes no sense to me. when you're driving over a 100 MPH and you glance at your gauge you can't quickly read the number if it is covered by the needle. You have to estimate that it lies between 2 numbers that you can read, in other words you have to do a mental calculation. I know this seems silly but when you're hauling *** you only want to glance at the gauge for a millisecond or so to get your reading then get your eyes back on the road.
Old Jan 28, 2002 | 04:21 PM
peejay's Avatar
Old [Sch|F]ool
sweet! BTW that's where the old trick comes in where you put your gauges in crooked - you align the gauge so that when it reads what it should be reading, the needle is pointing straight up, that way you just glance down and if the needle is pointing up you know that it's good. That's why I want a gauge and not one of those handheld units that you have to tape to the dash.
Old Jan 28, 2002 | 10:48 PM
amemiya's Avatar
I don't know about you guys but I remember where the numbers are at or maybe I can see it dunno never had that problem??????
Old Jan 29, 2002 | 01:49 PM
carcrazy's Avatar
Mine runs about 800-900 degrees idling around town. On the freeway, it will run a solid 1200 degrees and dip down to 1100 sometimes when I lift the gas.
regards
Rick
1993 RX-7
Old Feb 1, 2002 | 10:25 AM
R-magic's Avatar
Anybody knows where I can get a greddy fitting for my egt sensor. I just need the fitting that taps into the downpipe. I heard they are on backorder. Any help would be great. Thanks!
Old Feb 3, 2002 | 09:45 AM
penko's Avatar
Mine reads 1450f 6 inches from the turbo
