Haltech resistors on injectors?
Old Nov 6, 2005 | 06:56 PM
GOTBANNED?'s Avatar
Boost Addict
I was going through some haltech stuff and noticed you can set the settings of injectors you are using like say my secondaries are hi-impedence and my primaries are low-imp so doe sthis mean i don;t have to use resistors on my high-imp. injectors? i can just set it in the comp.?
Old Nov 7, 2005 | 03:48 AM
RETed's Avatar
No, this is not a Power FC.
As long as you're using one fuel injector per injection channel, the Haltech is fine.
-Ted
Old Nov 7, 2005 | 10:44 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
Exactly, the haltech drivers can each drive low imp. injetors and high, but the problem is if you combine them in one driver. But, in the long run, i would recommend your injectors be either all low or all high.
Old Nov 8, 2005 | 04:35 AM
sbd's Avatar
sbd
The point being what?
Old Nov 8, 2005 | 09:57 AM
MrRx's Avatar
Rotary on a budget
to keep from stressing one driver more than the other..
Old Nov 8, 2005 | 11:18 AM
sbd's Avatar
sbd
Old Nov 8, 2005 | 01:34 PM
EFI Tech Wannabe
The point being, that when you have low imp. injectors paired with high imp. their flow caracteristics are different, given their voltage demands, even though the manufacturer says their drifers can adapt to each injectors needs, they might be doing different things under the same conditions.
And finally yes, mixed matched injectors might cause havock with the drivers.
Old Nov 21, 2005 | 11:11 PM
GOTBANNED?'s Avatar
Boost Addict
thanks alot.
Old Nov 21, 2005 | 11:13 PM
GOTBANNED?'s Avatar
Boost Addict
**** totallty forgot to check this thread. thanks alotr guys
Old Dec 17, 2005 | 10:34 PM
TurboIIGuy's Avatar
Driveline Killer
yeah dont mix!!!!
Just like alcohol man.....Never mix dark with clear!!!
HaAHaha
Old Dec 18, 2005 | 04:09 PM
funklove's Avatar
In rotor we trust!
high an low
I have bought KGPARTS's fuel rails with injectors for my 13RE cosmo. Primaries are siemens deka 3105, and secondaries are bosch 0280150846. All are low-impedance I think. Are they P&H? And do they work properly with E11 driver?
Old Dec 19, 2005 | 06:26 AM
RETed's Avatar
No problem.
-Ted
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
