can i save this rotors?
Old Oct 31, 2005 | 11:15 AM
SpAm@FC's Avatar
Hi guys... I have found some parts of a 13B NA for free
so i want to ask... can i save this rotors? looks like rust 2 me
i've tried it for 5 minutes to clean them with break cleaner and rust-killer, but didnt try it to long... here are some pics
can i save them? maybe with some metall-polish or a fine sand-paper?
Old Oct 31, 2005 | 12:11 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
easy off oven cleaner my friend....... best on carbo deposits...
You don't neet to get the compression divots spotless, just get all the carbon out of them.. the surfaces need to be totally free of any gunk...
Metal polish isn't going to do schnit...
You can use really fine sandpaper, like 600 grit or higher, but really lightly, you don't want to remove any metal, only the gunk and DO NOT use it in or around the apex seal, side seal or corner seal grooves... only on the flat surfaces.
Old Oct 31, 2005 | 12:13 PM
in this pic... you need to look at the apex seal groove... about 1/2 inch from the left side, it looks as though the end piece may have been wobbling..... could just be the pic... but you need to mic the grooves out with a NEW apex seal and make sure they are in tollerance as per the FSM.
Old Oct 31, 2005 | 12:35 PM
Aaron Cake's Avatar
Engine, Not Motor
Scouring pad and carb cleaner. For tougher rust deposits, use Naval Jelly.
Old Oct 31, 2005 | 01:52 PM
SpAm@FC's Avatar
what is a scouring pad? pls give me a pic if you can
and what is Naval Jelly?
thx
Old Oct 31, 2005 | 02:29 PM
SpAm@FC's Avatar
ok, I've figured out what a souring pad is... but whats about the surface? i think the will do scratches into the surface of my rotor or not!?
Old Nov 1, 2005 | 08:41 AM
Aaron Cake's Avatar
Engine, Not Motor
Minor scratches in the rotor are fine. The only area you want to keep the scratches to a minimum is on the thrust surfaces (side bearings).
Naval jelly is a rust removing gel. You brush it on the rust, let it sit a few minute, then rinse it off.
Old Nov 1, 2005 | 10:51 AM
SpAm@FC's Avatar
k, big thx! will buy this stuff tommorow
Old Nov 1, 2005 | 11:33 AM
Mx6-Rx7 Addict's Avatar
Brap Brap Brap
I like to let rotors sit in carb cleaner from napa in liquid form. Bad bad stuff, but does a good job. Either that or mineral spirits.. Let them sit for a few days and then scrub them with spray carb cleaner.
Those rotors will be fine as long as the apex seal clearance is ok. Also check the rotor bearings to see if any copper is showing. I think 20% copper is allowed to show ?? Someone correct me if im wrong.
-Justin
ZacMan
Sep 19, 2015 09:20 PM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
Ian_D
Sep 6, 2015 10:38 PM
