project pics
Old Oct 30, 2005 | 04:25 PM
87 t-66's Avatar
not a drifter
project pics
http://www.teamfc3s.org/forum/showth...635#post492635
Old Oct 30, 2005 | 04:42 PM
87 t-66's Avatar
not a drifter
here ill put the pics in this thread...car is an 87 t2...
fuel...
front...(not secure but you get the idea...)
Old Oct 30, 2005 | 04:43 PM
87 t-66's Avatar
not a drifter
inside...
i just ordered a new exhaust housing for my turbo and am waiting to switch it out...
Old Oct 30, 2005 | 04:44 PM
87 t-66's Avatar
not a drifter
trying to figure out what all i can remove...anyone know off hand what these plugs are for? im assuming a couple are for the ps/ac that i have removed
Old Oct 30, 2005 | 04:45 PM
87 t-66's Avatar
not a drifter
no mouldings/badges...
Old Oct 30, 2005 | 04:52 PM
88t2romad's Avatar
(_8(|)
looks good man, im a fan of the no-moldings.
Old Oct 30, 2005 | 04:59 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Coming along!
Old Oct 30, 2005 | 05:02 PM
Garoad's Avatar
Sweet. The no-moldings dont look bad at all.
Old Oct 30, 2005 | 05:18 PM
McWheels's Avatar
Living, Breathing Nopiman
wow. I love the front-end of the FC's...
Old Oct 31, 2005 | 06:12 PM
87 t-66's Avatar
not a drifter
anyone know what i can get rid of from under the dash?
Old Oct 31, 2005 | 07:21 PM
Digi7ech's Avatar
I break Diff mounts
Cool.
I'm not a fan of mounting the FPR against the firewall. IRC it might be against NASA or something regulation as well. BUT I heard something like that a while ago.
I placed mine on the drivers strut tower. May be a tight with with your IC piping.
Old Oct 31, 2005 | 07:41 PM
87 t-66's Avatar
not a drifter
i believe to race in the scca you MUST mount it on the firewall...someone correct me if im wrong?
Fumi's Avatar
Addicted to the PNW
god i love fcs without molding.
each time i see it it looks better and better.
did you use body filler or what to fill in the gaps from the molding?
Old Oct 31, 2005 | 07:47 PM
speed_monkey's Avatar
affen
I think the best way would be to remove the moulding, then weld a strip of metal in. Then go back with the bondo.
Old Oct 31, 2005 | 07:49 PM
slomo85's Avatar
Rexistered User
as do i. i wanna tap the metal out, and grind smooth. won't body filler crack out over time, as well as add more weight. although it may not weigh very much, i have no idea how much it does...
meh, probabally woulden't add more than 5-8 lbs, too little to be concerned with if that is what he did. expecially with more power, yeah baby, yeah....
Old Oct 31, 2005 | 07:50 PM
slomo85's Avatar
Rexistered User
i was thinking of that, but that stuff is too thin, and would warp too much. at least in my experience w/welding...
edit, i think it's sad after all that work you did, and were getting vamped about just the removed mouldings, lol. i'll try to look at those plugs for ya, although icemark would probabally know what they are off the top of his head or something, lol...
Old Oct 31, 2005 | 08:27 PM
JABrx7's Avatar
where in ohio are you ?
Old Oct 31, 2005 | 08:32 PM
Dom_C's Avatar
yea what did you use to fill the moldings. I'm considering this my self
Old Oct 31, 2005 | 09:16 PM
jasmine's Avatar
Racer Chick Jasmine
I don't think so. I'm a former rally Chairperson from the Rocky Mountain Region, and with all the other mods the car will be in the Open class in any Rally group, and basically anything is permitted as far as moving things around, as long as it is not an obvious safety problem. I seriously doubt if any tech inspector would notice it anyway. I seem to recall a big discussion on our mailing list over rerouting fuel lines and so on, but I don't recall if we ever found anything about it in the rules. It does not affect the performance of the car so it shouldn't be a big deal.
As for the Solo divisions, I'm really not sure. Again though, I don't think any tech inspector would notice it, unless they were familiar with the stock layout of an RX-7, and a lot of them aren't. The rules change every year, and the complete rulebook can be found at the link below - I am on dial-up so I couldn't download it (13 megs!). It depends highly on what class you want to race in (you are pretty much eliminated from the stock classes anyway). Again though, the tech inspectors will most likely only look under the hood to determine the engine size and manufacturer, presence of a turbo, and other obvious things. They will not notice this, but I wouldn't say anything about it either. My advice... find a mailing list for an SCCA Solo group in a completely different part of the country than you are, and ask someone on the list about it. You will more than likely start a huge discussion over minor technicalities, but that way, you don't alert anyone in your area
http://www.scca.org/_filelibrary/File/2005SoloRules.pdf
I used to trace fuel lines, intakes and so on, to look for abnormalities, but that was just to be a bitch, and because I was also competing that year. I think there is now a rule that the tech inspectors can not be competitors. I will admit to reclassing cars on minor (but valid) technicalities to avoid having to compete with them, and I recall one sunny winter day I had a guy re-install his back seats before I would let him enter in the production class. Of course, other people alerted me to that one, and it was an obvious rules violation. It is all very tricky, and classing a car is based on what you can and can't get away with. We all try to do things we think will not get noticed. I had a lightweight flywheel and some other minor things in my Subaru (so did two other people), which is a clear violation of the P-GT class rules, but nobody ever said anything, even after they knew about it.
Old Oct 31, 2005 | 09:21 PM
jasmine's Avatar
Racer Chick Jasmine
Oh wow! Now that the photos finally downloaded, I'm thinkin this might get noticed, but looks like it is on the firewall, so probably ok.
Old Oct 31, 2005 | 10:33 PM
NOPR's Avatar
Rotary Apprentice
you must tell us how you did the moldings! and also what you will do about the bumper moldings. and where in ohio you are. also, clean that bitch! it looks like its shiny under all that dust/dirt!
Old Nov 1, 2005 | 03:21 PM
87 t-66's Avatar
not a drifter
I am in columbus, ohio. I actually did the mouldings last year...i used bondo which i know isnt the best way to do this. I havent noticed any cracks yet but if it does crack ill fix it, no biggie. If you notice when it gets to the bumper on the back i sanded it down to smoothly transition to the back piece. On the front fender i just straight took off the whole piece. I know i need to clean it...There are a bunch of kids in our garage that are obsessed with hondas and all they do is body work all day, its really annoying. Im waiting until i get it pretty much finished to totally clean EVERYTHING
Old Nov 1, 2005 | 03:22 PM
87 t-66's Avatar
not a drifter
i live on the osu campus but my car is actually in Findlay, ohio up about a mile and a half on RT 23
Old Nov 1, 2005 | 03:29 PM
87 t-66's Avatar
not a drifter
as far as thoes plugs...i have my old ps/ac and emissions crap in a box downstairs and will be pulling all the old plugs off and believe that i found most of them...ill keep you posted
Old Nov 1, 2005 | 04:36 PM
cool_as_crap's Avatar
He who smokes bitches
holy intercooler batman! that thing is huge! very nice work, i like the de-side molding you did. i may have to do that myself. great job though mein
