Is it safe to remove air pump?
Old Jan 23, 2002 | 04:09 PM
Is it safe? will gain some HP?
Old Jan 23, 2002 | 04:44 PM
Mahjik's Avatar
Mr. Links
Exclamation Re: Is it safe to remove air pump?
If you aren't running any cats (using a midpipe), then it's fine. Otherwise, you'll eventually clog your cat which will kill your boost.
As far as a HP gain? Going with a pulley kit to eliminate the Air Pump will probably give you an addition 15-20 HP (not rwhp).
Old Jan 23, 2002 | 05:03 PM
peejay's Avatar
Old [Sch|F]ool
Re: Re: Is it safe to remove air pump?
It doesn't even take that much HP to turn an A/C compressor, why do you think it takes 15-20hp to turn an air pump? The difference is more like 1-2hp at the very most.
Old Jan 23, 2002 | 05:57 PM
Mahjik's Avatar
Mr. Links
Re: Re: Re: Is it safe to remove air pump?
The underdrive pulley kits (as I said above, pulley kit) underdrive the engine driven accessories to free up HP for the engine.
I didn't say simply unplugging the air pump would release any HP.
Old Jan 23, 2002 | 07:32 PM
peejay's Avatar
Old [Sch|F]ool
I still doubt a 15-20hp gain even if you removed the belt entirely (no accessories at all).
Old Jan 23, 2002 | 08:46 PM
Mahjik's Avatar
Mr. Links
Even the cheapest pulley kits that retain the air pump "claim" at least a 10 HP increase.
TKT POWER PULLEY KIT
This simple effective design under drives engine-driven accessories by 25%, improving their reliability while releasing about 10 more HP for work propelling the car. CNC machined from billet aluminum and triple black anodized. Complete with new belts, grade 8 fasteners and easy to follow instructions. Installs in about 30 minutes with basic hand tools.
I would imagine some of the better pulley kits could release a little more power but I'm sure it all depends on the car.
Old Jan 23, 2002 | 08:50 PM
Mahjik's Avatar
Mr. Links
Arrow
Check out the GReddy & RP Triple Race Pulley kits:
http://www.rx7.com/cgi-local/3catalog.cgi?cat=3&part=1
Old Jan 23, 2002 | 10:17 PM
peejay's Avatar
Old [Sch|F]ool
well of course they CLAIM it...
Old Jan 23, 2002 | 10:54 PM
Mahjik's Avatar
Mr. Links
That's all most of us can go on unless we all have these parts and dyno's in our garages to test each and every one of them....
GReddy claims 350-400 RWHP on pump gas with their TD06 turbo kit. I guess because they "claim", that's not exceptable so it doesn't REALLY give that much....
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
