Microtech Diagram error in ignition wiring or harness error?
Old Oct 28, 2005 | 10:27 AM
SonicRaT's Avatar
Super Raterhater
I just took a look at my LT8 harness and I noticed that for some reason, there's a discrepency with the ignition wiring, or my harness.
Microtech's diagram shows:
Grey/Red - Ignition ouput #4
Grey/Black - Ignition output #3
According to the image that provides the pinout, these would be the CENTER two pins of the 6pin connector.
Now, on my harness, the GREY/BLACK and the GREY/RED are wired on the outside (left most) of that connector, which would make it instead:
Grey/Red - ignition output #2
Grey/BLACK - Ignition output #1
So, is my harness incorrect, or is the diagram incorrect? Should I be using the middle pins for trailing, or the outside?
Old Oct 28, 2005 | 10:41 AM
SonicRaT's Avatar
Super Raterhater
Damn, can't attach images in this section?
Old Oct 28, 2005 | 06:15 PM
TwistedRotors's Avatar
Compression Tester Guy
Hey Sonic, awlright dude I just ran out to my car with MT ignition drawing in hand and yes...it sounds like your harness is wrong.
Looking at the back of the connector (wires coming from the harness):
grey/black - bottom middle (ign output 3)
grey/red - top middle (ign output 4)
grey/blue - top right (ign output 0)
I hope that helps.
-John
Old Oct 28, 2005 | 07:08 PM
SonicRaT's Avatar
Super Raterhater
Thanks, exactly what I needed!
Old Oct 28, 2005 | 07:14 PM
Glad I could help!
-John
Old Feb 4, 2012 | 05:19 PM
13bpptok's Avatar
I hope that helps.
-John
hi there this has also just helped me thank u
but i also i must ask i have a fd is this using fc coils 13bt thanks
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
