Please help, 86 Is Flooded Again!!!
Old Oct 27, 2005 | 02:40 PM
ajlsro1's Avatar
This car recently had new hi-flo cat w/slightly larger pipes put on. (replaced original precat system). Took into Mazda shop and they found marine plugs in the engine!! Don't know how the hell or who the hell did it!! Also had old wires.
Anyways, had the plugs replaced w/new plugs, wires. This seemed to help with the jerking problem between 2500 and 4000 rpms which started after the exhaust was put on. Thinking the cat and pipes couldn't have caused that, we asked for the tune up. Which is when we found out about the boat plugs!!
Brought car home today and when I went to restart it, it is flooded again. I know how to do the deflood procedure and I am at work, so I guess I'll do it again once I get home. FRUSTRATED
Just curious if anybody thinks that the new cat may have caused this? Could the flooding happen after new plugs and wires are placed in? Any ideas? thank you, thank you thank you
Old Oct 27, 2005 | 02:44 PM
J-Rat's Avatar
Alcohol Fueled!
I doubt the new cat is causing flooding problems. Most times the causes are:
1. Faulty sensor (Thermosensor, IAT, etc).
2. Low compression
3. Leaky injector
4. Not letting the car warm up before shutting it down again
Old Oct 27, 2005 | 02:46 PM
ajlsro1's Avatar
Does low compression mean the engine is dying?
Is a compression test the best idea?
Old Oct 27, 2005 | 02:51 PM
J-Rat's Avatar
Alcohol Fueled!
Well, I am a big fan of doing the easy stuff first.
I would (in this order):
1. Inspect area where the aforementioned work was performed. Look for loose stuff..
2. Inspect/re-clean plugs
3. Check codes
4. Compression test
If all those look good, then it points to the injectors. Here you have 2 options. You can get the H-Bleeder from Mazdatrix, or you can have your injectors professionally cleaned and flowed.
Old Oct 27, 2005 | 02:54 PM
ajlsro1's Avatar
Thanks JRAT, I appreciate the help. I think the guy at the mazda shop wants the car, and I don't trust his advice. Everytime I take it to him he wants to buy it, and I get a weird feeling about what he's telling me.
Again, thanks for your time.
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
