How many MOUNTS are there in our cars?
Old Jan 23, 2002 | 04:12 AM
ROSHX7's Avatar
Besides the ENGINE mounts, where else are there MOUNTS that could go bad?
Old Jan 23, 2002 | 06:58 AM
HAILERS's Avatar
HAILERS
Three on the differential and one on the transmission. Two on the engine. The front mount on the differential has a tendencey to go bad.
Old Jan 23, 2002 | 03:30 PM
ROSHX7's Avatar
Thanks hailers, if the front mount on the diff goes bad, what happens usually?...what sort of symptoms.
Old Jan 23, 2002 | 03:36 PM
HAILERS's Avatar
HAILERS
The front of the differential will rise up and strike the body. Notice that the driveshaft is attached to the front of the differential, and just imagine what harm is being done to the u-joint on the driveshaft(u-joints are not replaceable on factory driveshaft so you have to buy another driveshaft$$$$$$$$$). You'll also get a thump when stopping. Its a son of a gun to replace. Not just remove two nuts and put a new one on type thing. There is a description of how to done last December somewhere. Rates right up there with doing work under the dash, just harder.Oh yes, the thing cost 80-125 bucks.
So a straight answer to your question about what happens, is, you get poorer, your voice rises in anger and curse words, and you lose the better part of a saturday replacing it.
Old Jan 23, 2002 | 06:18 PM
Dyre's Avatar
Your Opinion is Wrong
It makes very loud cluncking noises every time to accl qucik, or decell qucikly...
I know... mines broken
Alot of people replace the mount with a piece of angle iron instead of the mounts to keep form replacing it every 2 months.
Old Jan 23, 2002 | 06:42 PM
Scott 89t2's Avatar
SOLD THE RX-7!
also 2 subframe mounts
most common breaking are the pass. side motor mount and front diff mount.
Old Jan 23, 2002 | 07:06 PM
akageals's Avatar
Yeah...what Scott said. My passenger side motor mount was broken and I replaced the "y block" transmission mounts (2 of them). My selector lever would move around alot when on rough roads...now it does not move at all.
Todd
Old Jan 24, 2002 | 02:38 AM
ROSHX7's Avatar
When I launch my car @ 4000rpm, it get a constant banging in the back. I thought that was from the shocks or something, but I guess this could be the diff hitting the undercarriage? So the mount could be bad?
Old Jan 24, 2002 | 05:55 AM
HAILERS's Avatar
HAILERS
ROSH7 YEP. It could be tearing up your driveshaft ujoint also. Dyre gave a good description.
just having fun.....you also have three mounts for your fuel filter. All of mine are broken.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Wolf_
Aug 11, 2015 04:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
