Removed Dashed Now Starting Problems
Old Oct 24, 2005 | 07:22 PM
DwArF's Avatar
vrrmmmmm
Question Removed Dash Can't Start!! I Broke My Rx7
I was working on my Rx7 today so I can pull out my carpets and dye them and make new panels, like Dr. How To. After I get my dash all out and disconnected my Harness, I think it was. 3 connectors, 1 black and long, 1 white and long, and 1 skinny white. I started my car to see if it would work and it did.
So I was putting everything back together becuase she is a daily driver, and I have work tonight at 1130pm, wired up my gauges and placed them neatly on my steering column with some duct tape. and Reconnect the 3 connectors, and my car doesn't start. It sounds like it wants to, but it just wont.
Why Did I break my Rx7?
Old Oct 24, 2005 | 07:30 PM
DwArF's Avatar
vrrmmmmm
Here is what it sounds like, the 2nd time i tried to start it it gridned from trying to start it again to fast.
http://media.putfile.com/ConvertedFile67
Old Oct 24, 2005 | 07:54 PM
trochoid's Avatar
Old Fart Young at Heart
Best guess would be fuel pump relay, if your car has one, I don't know.
Old Oct 24, 2005 | 08:03 PM
DwArF's Avatar
vrrmmmmm
What is that? I have an 82 GSL.
Old Oct 24, 2005 | 08:53 PM
rx7adam's Avatar
you probably don't have a fuel relay.I think olny the 84/85 models had relays I think?
Old Oct 24, 2005 | 08:54 PM
Myc1972's Avatar
1981 Mazda RX-7 GSL
I think i can hear his fuel pump running on the recording. Have you checked
the fusible link bellow the steering column? Might have gotten disconnected,
or broken accidently. I think it might have a black wire with yellow stripe
connected to it.
Also check your fuses and other fusible links.
Old Oct 25, 2005 | 12:02 AM
DwArF's Avatar
vrrmmmmm
I checked my fuses and they were all intact. How do I check my fusibile links? Those are in my engien bay right?
Old Oct 25, 2005 | 12:12 AM
DwArF's Avatar
vrrmmmmm
I went out to push my car to shut my garage and it started right up. I guess it was just flooded.
Old Oct 26, 2005 | 04:32 PM
DwArF's Avatar
vrrmmmmm
Ugh, It sitll doesn't start!
DOUBLE YOU TEE EFF
Old Oct 26, 2005 | 05:09 PM
DwArF's Avatar
vrrmmmmm
I pulled trailing plugs and it made three PSSST PSSST PSSST noises, I think I have compression.
I looked into my carburetor and fuel was going into it.
there is also white smoking coming out of my tailpipe as it tries to start. whitish blue kinda i think. also some came out of the carb when i looked into as my dad tried to start it
Old Oct 26, 2005 | 06:31 PM
trochoid's Avatar
If you flooded it before, pull your plugs and clean them. I've had to bead blast new ones, once they were flooded out. Brake cleaner wouldn't clean them up enough.
Sounds like your starting problem may not be related to the dash, but I would check all the connections again, especially near the ignition switch. You also may want to look over the starting diagrams in the FSM, to see if you missed something.
Old Oct 26, 2005 | 06:39 PM
DwArF's Avatar
vrrmmmmm
My plugs had spark, enough to shock me and it scared me.
What do flooded plugs look like? The ends of my trailing plugs looked brown and wet
Old Oct 26, 2005 | 06:47 PM
lovintha7's Avatar
Suicidal Death Missile
The wetness is flooding. Take all the plugs out, spin the motor over a for a few seconds. Clean the plugs off, so they're nice and dry. Pour a small amount of motor oil or 2-stroke oil into each of the primaries. Put the plugs back in, and connect the wires. Try starting it now.
Old Oct 26, 2005 | 06:53 PM
Myc1972's Avatar
1981 Mazda RX-7 GSL
Yeah, some are in the engine bay, but there is one that is under the steering
wheel. Check out my thread to know what to check. Since your problem
started after re-installing your dash it's worth checking it out:
https://www.rx7club.com/1st-generation-specific-1979-1985-18/starting-problem-electrical-444665/
Hope this helps!
Old Oct 26, 2005 | 06:55 PM
DwArF's Avatar
vrrmmmmm
What are the primaries
Old Oct 26, 2005 | 11:06 PM
smnc's Avatar
EliteHardcoreCannuckSquad
The primary intake butterflies...
Old Oct 27, 2005 | 03:47 PM
DwArF's Avatar
vrrmmmmm
I went out there this morning and it started right up first try, and started smoking ab it, then it died
Now it doesnt start again, it just cranks for a few seconds and then makes another noise and doesnt do it anymore, like it's been doing
Ima go buy new plugs and try it again
Th0m4s
Feb 26, 2019 02:04 AM
OrangeMax
Sep 4, 2015 10:42 AM
