My GT42 dyno chart
Old Oct 23, 2005 | 10:56 PM
AZ'sFastFD3S's Avatar
My GT42 dyno chart
17 psi and 20 psi on 100 octane unleaded.
Old Oct 23, 2005 | 11:01 PM
I ran the car at the drag strip last night and went 11.60 @ 123 @16psi. I was having Profec B spec 2 probs with boost. I will go back to the track at 20 psi and try again soon.
Old Oct 23, 2005 | 11:47 PM
z8cw's Avatar
respectable numbers, well done
Old Oct 23, 2005 | 11:51 PM
I also made 562 @ 22.5 psi but the graph is wavy from hitting the warning on the profec B.
Old Oct 23, 2005 | 11:53 PM
Wargasm's Avatar
Weird Cat Man
You've got 550/1600 injectors and you're pushing nearly 550 rwhp? You must have a good pump and be running some high pressure!
Old Oct 24, 2005 | 12:03 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
sweet numbers, must be crazy fast to drive a 500 rwhp FD!
Old Oct 24, 2005 | 12:59 AM
87GTR's Avatar
great numbers look like the profec b is having a hard time syncing 2 wastegates or your springs are too small. making your power bounce around. looks like a hell of aride from 4k up. what pump are you using? your injectors should be mostly maxed out. the wavy lines on the big end can also be cuased from not enough fuel. like your injectors are maxing out or fuel pressure on the rail is dropping off.
Old Oct 24, 2005 | 08:27 AM
I am running two nippo pumps at 13 volts. I was watching the fuel pressure on the dyno passes and I was getting no pressure drop. I have the base pressure at 38 psi on the fuel.
Old Oct 24, 2005 | 08:39 AM
sevenin7's Avatar
AZ'sFastfd3s
Is this power , at the wheels or flywheel ?
Thanks.
Old Oct 24, 2005 | 09:42 AM
pluto's Avatar
congrats....good hp #'s
Old Oct 24, 2005 | 10:12 AM
fd3virgin's Avatar
Originally Posted by sevenin7
AZ'sFastfd3s
Thanks.
they should be at the wheels.
Old Oct 24, 2005 | 11:21 AM
PDViper77's Avatar
HAHA V8
congrats, and who tuned it?
Old Oct 24, 2005 | 11:29 AM
Trevor's Avatar
I tuned the fuel around Pluto's timing map.
IDC's were pretty high at 22 psi...around 92% if I remember right.
Need to beat that boost controller into submission, rev it out to 8200, and feed it some C16. With that much fuel pump (it has 2 Supra pumps with good power) we can turn up the base pressure to 49 psi or so and retune. 13.5% more fuel...673 crank won't be a problem.
Old Oct 24, 2005 | 12:54 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Very nice!! Congrats on the great numbers. Looks like these turbos are capable of some rediculous numbers!!
Zach
Old Oct 24, 2005 | 01:05 PM
FD Rey's Avatar
I brake boost
wow! Very nice! Good to see the numbers on paper.
Old Oct 24, 2005 | 08:22 PM
Trevor's Avatar
Vid:
http://www.spacerat.net/Dori/Mattsdynopulls.wmv
Right click-save as
Old Oct 24, 2005 | 08:47 PM
gcbutter's Avatar
I just watched the video...WOW!
Old Oct 24, 2005 | 08:57 PM
lastphaseofthis's Avatar
My job is to blow **** up
can i be your friend? can i get a ride? i need to go to the mall... lets take your ride!
terrifying vids.
Old Oct 24, 2005 | 09:32 PM
kabooski's Avatar
Laying Down Rotary Law
Nice! love the sound the turbo makes
you likely need stiffer wastegate springs
the Profec can only do so much past the spring rate
Are you using the 71 , 74 or 76mm version?
T6 frame 1.15 ?
Old Oct 24, 2005 | 09:40 PM
93 R1's Avatar
badass.
Also curious which version of the 42 you have
Old Oct 24, 2005 | 10:25 PM
RX7 RAGE's Avatar
Top Answer: 1
damn, your car sounds like a 747 jet!
Old Oct 24, 2005 | 10:44 PM
BoostedRex's Avatar
One word DAMN!!!!!!!!!!!!!
Old Oct 24, 2005 | 10:54 PM
FB II's Avatar
ohhhhh my goooooooooooooooooooddddnnessssss. L O V E I T!
Old Oct 24, 2005 | 11:17 PM
Congrats Matt! Looks like that Gotham motor is holding up well for you
Old Oct 25, 2005 | 12:00 AM
Kyro-2's Avatar
TT LS1
Nice buddy well have to race again when my cars done.
