2nd gen oil cooler for sale
Old Oct 22, 2005 | 05:40 PM
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
i know a buddy of mine liked to use fc oil coolers on his first gens. i have one for sale that came out of parts car. how does 50 bucks shipped sound? here is a picture
Old Oct 22, 2005 | 06:12 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Sounds like it is in the wrong forum.
Old Oct 23, 2005 | 07:02 PM
rxtory's Avatar
Roll to Heaven in a RX-7
do the oil cooler fit right in and connect no problem or do you gotta do alittle work and get new hoses for them
Old Oct 23, 2005 | 07:52 PM
smnc's Avatar
EliteHardcoreCannuckSquad
You need new hoses and a way to mount it...
I think ISC Racing has a kit to fit it...
Old Oct 23, 2005 | 08:07 PM
trochoid's Avatar
Old Fart Young at Heart
https://www.rx7club.com/1st-gen-archive-71/how-install-fc-oil-cooler-1st-gen-write-up-pics-462616/
Your welcome.
Old Oct 27, 2005 | 06:43 PM
rxtory's Avatar
on my 82 the oil cooler is right below the radiator, not like the one that you did. do you think a fc oil cooler will be able to get under there. i mean how much bigger is a FC oil cooler then a 82 oil cooler
Old Oct 27, 2005 | 07:59 PM
FB II's Avatar
i am running the STOCK TII oil cooler lines w/ the TII oil cooler on my 12a. bolts right in no problems and it's mounted right under my intercooler. i looooove it. was beyond easy.
Old Oct 27, 2005 | 11:58 PM
rxtory's Avatar
i can get a FC N/A oil cooler but will i need to get new (modify) brackets to hold it under the radiator, or will the FB one work or FC. Also what about hoses are they interchangeable for FB and FC
Old Oct 28, 2005 | 01:27 AM
FB II's Avatar
yep, as stated the stock TII lines will work on your 12a
Old Oct 28, 2005 | 02:00 AM
steve84GS TII's Avatar
FB+FC=F-ME
All FC oil coolers are the same and are the same size as FB coolers.
They mount up easier because of their rearfacing,stubby mounts.The swiveling banjo bolts also make hose routing easier and eliminate the splitting issue the FB coolers had.
As FB II stated,the engine ends of the FC hoses will bolt to almost any rotary engine.The banjo cooler ends of the hoses are unique to the FC unit.The FC hoses are not immune to the common leakage issues however,so use caution when installing old factory fabric lines.
All in all,its a great mod and an easy to find part(usually)
Old Oct 28, 2005 | 09:15 AM
Glazedham42's Avatar
Resurrecting Gus
That is a good deal. Someone needs to grab that up. You'd be hard pressed to find a cooler in that good of shape, for that price if you were looking for one....
Old Oct 28, 2005 | 03:05 PM
like he said ive got 3 people with dibs on it if the first person doesnt respond to me by the end of today it goes to number 2.
Old Oct 28, 2005 | 08:58 PM
setzep's Avatar
Correction, the FC cooler is a bit longer than the FB cooler. I think it's only a inch though. Same height.
Old Oct 29, 2005 | 02:50 PM
sold
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
