Starting to finalize the details for my project Cosmo
Old Oct 19, 2005 | 02:51 AM
87GTR's Avatar
Right now I am working on my current 20B project car. 1990 JC Cosmo Type S.
side port 20B
fresh rebuilt
Haltech e11v2
profec B Spec 2
Jacobs box
3 X 1680 injectors (replace secondary injectors)
replace FPR
replace PD
add 2nd pump ( most likey a walboro 255)
ssb fuel lines 8an feed and 6an return
fuel pressure guage
aquamist water injection
custom twin pass radaitor
custom bar and plate FMIC
GT40R 88mm with 1.06 a/r
Tial 44mm gate
FC cluth and brake pedal
FC 5 speed trans
hks twin plate
This is not going to be drag car.
The plan is to make 500 - 550rwhp and spool very quick, as now just crusing the car around it almost nevers gets above 4000rpm. crusing on the highway at 100kpm its at 2200rpm. so I want it to be able to start spooling very quick
here is the comp map
in looking at the comp map, Im thinking it will make around
450 - 460 @ .9 - 1 bar
~500 @ 1.1 to 1.2bar
~550 @ 1.3 - 1.4bar
I know we all like big turbo and I though about a GT42R, but Im not planning on making 700 - 800hp. I wounder if there is something in the middle like a GT41..
any comments questions or recommations are welcome.
here is a link to project car right now
http://ultimate-cosmo.cyberosity.com/gallery/v/
Old Oct 19, 2005 | 07:26 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
If your going to throw the walbro in the tank next to the stock cosmo unit I would make sure they flow the same. I don't know first hand but I have read that if there is a difference in fuel pressure where both pumps meet it can create a problem.
-Deztin
Old Oct 19, 2005 | 08:58 PM
87GTR's Avatar
yes I think your right I will just run a pair of walbro's and ditch the 15 year old comso pump.
Old Oct 19, 2005 | 09:01 PM
Merovingeon
Veteran: Air Force
just run the GT42R!!!
neil
Old Oct 19, 2005 | 10:48 PM
87GTR's Avatar
not sure if the gt42r will bring on the boost quick enough
im starting to lean to the GT42R but I have only found 1 dyno sheet with it. and it was only @ 8psi. is there more sheets out there?
I asked him when did the turbo start to spool but he never answerd back. anyone else with this turbo care to share when does it start spooling?
Old Oct 19, 2005 | 11:30 PM
GOTBANNED?'s Avatar
Boost Addict
If your talkin about 203rotor i have been in the car many many times and spool is no prob u're pretty much flying at 3000rpm !
Old Oct 20, 2005 | 12:30 AM
87GTR's Avatar
yeah I sure thats the car, the white fc. Has he turned up the boost? redyno'd? Im trying to find out more info before I take the full plung. I would like get an idea on when it starts to spool.
Old Oct 20, 2005 | 05:44 AM
DMRH's Avatar
I'm going to pull my finger out this weekend & get some pics of that manifold for you.
Have to drop by that guys place on Saturday morning.
REgards
Old Oct 20, 2005 | 07:51 PM
paximus's Avatar
20B FD|20B Cosmo|S5 TII
87-
i just got my GT42R from aspec yesterday, i should have a dyno sheet for you in a few weeks, after the motor is broken in. remind me and i'll send it to you.
Old Oct 23, 2005 | 05:53 AM
87GTR's Avatar
REgards
cool thanks, Im doing JCI inspection next friday so after that I will start modding the car.
Old Oct 23, 2005 | 06:03 AM
87GTR's Avatar
Originally Posted by paximus
87-
kewl keep us updated. I went to a Garrett turbo shop here. they recommend a Garrett / HKS hybird. he said he can build it cheaper than GT42R
Garrett T4 flang 1.06 exh housing
82mm exh wheel
GT42 char dual BB
HKS 94mm Comp wheel
HKS T51 Kai comp housing
said it should spool quick on street ported 20B.
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
