Ebay ss t04 turbo..
I bought this turbo kit off ebay from ss autochrome... Well i let Porkperformance installed and there is no boost and the car have no spool power even i rev it to 5 or 6k rpm it well show 4 or5 psi boost. i check all the intercooler pipe there is no leak,check wg dumping pipe no leak,check vac hose they all seem right. But i have no idea what wrong...
Super t04 .60 .85 turbo from SS auto chrome
xs manifold with 40mm wg
50mm bov
stockport
power fc with base map tune by jason rx7.net
extreme fuel system and walbro pump
straight pipe N1 apexi
greddy pully
2 row greddy inter
avc-r boost controler
stock ign
If any one have experience with the same problem or know something about it please help me cause i miss driving my baby for moths.....
50mm bov
stockport
greddy pully
2 row greddy inter
stock ign
Can you turn the turbine by hand, does it feel like it binds up at all or requires a lot of force? And I assume rev means drive? Since you won't boost much in neutral
does anyone READ the fourms anymore? or do they just hop on and blindly type away..
'cause if you had read you'd know that ANYTHING from SSAC/XSPower.. whatever they call themselves this week. IS not worth the steam that flows off poo.You can pretty much count on those 'trims' being so far out in left field that your going to have to dissasemble them and get the RIGHT trim.
I'm going to guess that your compressor nut is locktite into place without actually being tight on the wheel it's self.. I've had two customers with XS power turbos that I've turned away ( wanting a system built around them) that had this oversight.
Originally Posted by jimmyrx72002
Yes i did that too. It's turn easy which it fine.
Well whenever this turbo blow it will buy Af 61 anyway or something with t04 flange
so have you driven the car? or are you revving it in neutral?
it should boost like hell with a .84 hot side.
maybe it only has a 5psi WG spring?
First of all I would check for some sort of boost leaks, its very common on newly installed turbo to blow loose a coupling or a line. What BOV are you using? It wasn't one of the ones that came with kit was it? The TiAL knock offs? That could be major leak there if it isn't functioning correctly.
Hell on one of my cars I blew pipes loose for first month or so before everything got lined out. You problem really does sound like some sort of leak.
Next I would suggest the turbo, one of the local guys here bought one of the cheapo ebay turbos and it has blown oil since start up.
Trending Topics
Yes. i drove it.Take forever to go up 60mph i have to keep the harza light on at all time. And yes i used the bov that came with the kit. I dont know the TiALknock offs or not but seem like its stay close when i rev it up. And why bov have anything to do with no boost. Guys i know i make a misstake bought that turbo so please help fix this prolem then i get me a better turbo later... thanks Helium rush5...
Sounds like you have more problems than the turbo itself. Fuel, ignition, bad boost leak, bad tuning, dare I say...low compression.
The BOV could be leaking boost, causing a no to low boost situation.
-Marques
-Marques
You get what you pay for. People that buy no name crap off of ebay for a fraction of the going rate for name brand components shouldnt be surprised......
I have a feeling this is related more to the install than the turbo itself. I know everyone loves to hate on the ebay stuff and a lot of times I dont disagree but this sounds like other problems other than the turbo. I am interested in how this will turn out. Please take it to a rotary performance shop and let us know how it turns.
Lets look back at when he said it takes forever to reach 60? Hell with a blown pipe it should reach 60 in a "normal" kind of way, is your leading ignition firing? If anyone has ever had leading coil go out on them will know what I am talking about, you have not power what so ever.
If motor starts pretty easy chances are your motor is fine.
I can't believe you bought an FD (13k or more?) but wouldnt spring the extra 250 bucks for a GOOD turbo. And now as soon as this one doesnt work instantly you're ready to just go buy another one? if you have enough money to do that why did you buy this piece of autochrome **** in the firstplace? I jsut dont get some people. when it comes to anything that requires precision and engineering stay the hell away from ebay.
