Stock 90 GXL S5 Dyno
Old Oct 15, 2005 | 02:58 PM
Tech_Greek's Avatar
Rockn' The Galant
Question Stock 90 GXL S5 Dyno
Well, the only thing I had was an intake and it was 100 degrees outside so I doubt it was doing my any good, it was on a mobile dyno.
It's still running really rich, even with the SAFC leaning it out according to the dyno guys, they want me to come back and get it tuned with them next week.
Are these decent numbers for an RX7 with 83k miles on the engine? I figured a little more but like I said it was 100 degrees outside.
AFAIK, the spark plugs and wires were replaced (doesnt look like it to me) and the oil was changed, the oil looked like crap so I changed the oil and filter...spark plugs looked fouled out but they are NGK's, I've also got rusted out exhaust so I have a feeling that could be causing it?
Also most of the bushings are shot in my car, could I be loosing power through that? I want to get my car back up to stock spec short of rebuilding it before putting the turbo on...
Run 1, 3 = 3rd Gear Pull
Run 2 = 4th Gear Pull (maxed out at 150mph he said before vibrations got bad)
This was with the SAFCII at -10% through the whole range and some ebay intake filter on there.
- Tech
Old Oct 15, 2005 | 03:05 PM
lnbrown5981's Avatar
Just take the blue pill..
damn, i've never seen that before, you have more torque than horsepower!
Old Oct 15, 2005 | 03:06 PM
Tech_Greek's Avatar
Rockn' The Galant
You're the fith person to say that to me today...
Old Oct 15, 2005 | 04:48 PM
Eternal_Gamer's Avatar
What happened to your horsepower?
Old Oct 15, 2005 | 04:49 PM
Tech_Greek's Avatar
Rockn' The Galant
I think I saw it running away when the big 900hp Cobra pulled up to Dyno
Old Oct 15, 2005 | 06:07 PM
Dom_C's Avatar
yea dude that's wicked low. . I'm thinking maybe you've got a clogged cat or something? that would also creat alot of back pressure which would cause your torque to be higher than your horsepower
Old Oct 15, 2005 | 06:10 PM
BlueS5's Avatar
Damn I miss having a RX7.
Weird.....I've always known rotaries to put down more horespower than torque.
Old Oct 15, 2005 | 06:13 PM
Tech_Greek's Avatar
Rockn' The Galant
That or my 5th/6th ports are STUCK closed...
Old Oct 15, 2005 | 06:14 PM
Andrew.'s Avatar
The end of an era
6 port sleeves working right? Still have acv and air pump? Its odd when i did my base tune for my fc i also hit 150mph in 4th gear, 155 to be exact, i was stoked lol.
Old Oct 15, 2005 | 06:15 PM
Tech_Greek's Avatar
Rockn' The Galant
No 6 port sleeves are not working right, they are ******* frozen and I'm pissed off..
Old Oct 15, 2005 | 06:18 PM
Andrew.'s Avatar
The end of an era
There's your answer, you had 4 of 6 ports working thats why you didn't get full hp. what afrs were you doing?
Old Oct 15, 2005 | 06:25 PM
SonicRaT's Avatar
Super Raterhater
Yeah, I had him check the second I saw the torque drop off, and sho nuff, they be stuck!
Old Oct 15, 2005 | 06:28 PM
Tech_Greek's Avatar
Rockn' The Galant
Dyno couldn't interface with his wideband...
Old Oct 23, 2005 | 09:28 PM
its interesting......i'd like to see a dyno with them working just to compare the differences
Old Oct 24, 2005 | 06:39 PM
arghx's Avatar
rotorhead
I dynoed my streetported s4 N/A when my ports were stuck closed and I was like wtf... so I wired them open real quick with some zip ties and I got an extra 20whp.
Old Oct 24, 2005 | 07:04 PM
SonicRaT's Avatar
Super Raterhater
Well, his are now removed. They were so stuck it was unbelievable, they had so much carbon buildup it took me almost 30 minutes to get them out of the damn engine, then the actuator rods were frozen shut, and absolutely refused to come off, so we just removed them completely.
Old Oct 24, 2005 | 07:22 PM
jacobcartmill's Avatar
just dont care.
well hey atleast the VDI was working...
now take that puppy back with no aux ports!
Old Oct 25, 2005 | 12:24 AM
Tech_Greek's Avatar
Rockn' The Galant
Plan on it, just waiting on the dyno to be laid out again.
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
The Shaolin
Sep 14, 2015 07:50 PM
Akaviri
Sep 9, 2015 03:56 PM
Clacor
Aug 14, 2015 09:17 AM
