650rwhp@32psi on a junked motor!
Old Oct 11, 2005 | 01:29 PM
61620B's Avatar
This is a 93 junked motor(detonated housings,flat apex seals, and 60/30 compression) with a T76 turbo and some of RX3MIST's intake and exhaust manifolds.
Here is the video:
650rwhp@32PSI
Here is the dynosheet:
650@32psi
Old Oct 11, 2005 | 04:49 PM
the_glass_man's Avatar
Will u do me a kindness?
OMG!!! In a SA!!! :****:
Old Oct 11, 2005 | 05:34 PM
kabooski's Avatar
Laying Down Rotary Law
is that dog box?
awesome numbers!
Old Oct 11, 2005 | 06:39 PM
BoostedRex's Avatar
NorCal 7's Co-founder
That is just plain scary!!!! Incredible and thanks for posting that!!
Old Oct 11, 2005 | 08:10 PM
rotarygod's Avatar
Rotors still spinning
That was at Rotary Reliability and Racing on Sunday. I was there for that. Fantastic numbers. That was an absolutely huge turbo. He was running a street ported 3rd gen block with GSL-SE 9.4:1 compression rotors. He had the stock 3rd gen lower intake manifold but had a large plenum welded onto the top of it. It used a large single plate Mustang throttlebody. No intercooler because he was running alcohol. It's compression is low and the engine does need a rebuild. He has another motor which he says is stronger. Another 1st gen there did 590 hp on a 13B.
Abel didn't dyno his car there but he did show off a 2 rotor 13B at his shop that has hit 983 rwhp!!!! I was chatting about it with Rick (Engman), Paul from Mazmart, and Jim Downing on Monday. They hung out with Abel on Sunday evening at his place.
Old Oct 11, 2005 | 08:29 PM
88fc3sw/HX83's Avatar
I think that would supprise even some of the piston guys!
Old Oct 12, 2005 | 12:02 AM
13BNUT's Avatar
I was there that day, it was crazy to watch that little first gen pull all that power, hey Rene maybe next time you can take your 616 to get it dynoed or even your RX3.
By the way will you be at Pomona on the 22nd and 22rd???
This time leave the wheelie bars off and see how high she can fly
Old Oct 12, 2005 | 08:37 AM
turboR1's Avatar
ErnieTKiLLA
I see 850 rwhp 13b's all the time. Not very hard to do if you know what your doing. Only problem is staying around the car to long. Meth hurts after a while.
Old Oct 12, 2005 | 08:47 AM
kabooski's Avatar
not any C16
Ari puts down 700
if there was a 850 c16 13B put there
then they could compete in Nopi Pro Street tire class
but there isnt
so its not as easy
Old Oct 12, 2005 | 09:50 AM
13btnos's Avatar
Originally Posted by kabooski
not any C16
Ari puts down 700
but there isnt
so its not as easy
So if Eddie Colon, Sporty Motorsports, went 7.34@180mph what kind of horsepower is he making on C16? From what I understand that car does not run on alcohol.
Old Oct 12, 2005 | 09:58 AM
kabooski's Avatar
True it does run C16
next time Gaby (my tuner) who tunes that car
comes down here
I'll ask him what #'s there car is putting down
Old Oct 12, 2005 | 09:01 PM
61620B's Avatar
With these kind of apex, it busted 650.......
Old Oct 13, 2005 | 07:35 AM
Spoolerr's Avatar
are those stock apex seals??
Old Oct 13, 2005 | 07:53 AM
APEXL8T's Avatar
boxed in and drawn out
good shots...
Old Oct 13, 2005 | 08:14 AM
turboR1's Avatar
ErnieTKiLLA
arent stock seals proven to handle 54psi.? I seen stock seals take bout 40psi 850hp a handful of times and not break any yet.. of course alot of other things did but no apex seals yet... they have been holding up so far..
Old Oct 13, 2005 | 09:34 AM
13btnos's Avatar
Do you have any shots of the housing? Man those apex seals are shot. What apex seals are those?
Old Oct 13, 2005 | 12:46 PM
LUPE's Avatar
WTF, I've never seen a seals like that !!!
Old Oct 16, 2005 | 12:37 AM
13BNUT's Avatar
Those compression numbers are true, they even used one old *** compression testing machine LOL
They had a whole lot of trouble firing it up, but when they did it sure was worth it
Old Oct 16, 2005 | 05:10 PM
Tripple 7's's Avatar
wow, thats insane
i guess i missed that. i was there at the dyno earlier. me j-rat and the other tucson guys split at about 2pm from the dyno
edit, this is Node on erics name btw
Old Oct 16, 2005 | 05:50 PM
pluto's Avatar
Looks like atkins seals to me.... I'm not sure why there was so much wear at the end of the seal but I would question the tolerance of the apex grove to the apex seal.
The1Sun
Sep 18, 2015 12:34 AM
The1Sun
Sep 7, 2015 10:21 PM
doritoloco
Sep 5, 2015 12:41 PM
