Sponsored by: CARiD
seals... and thier cost...
Old Sep 22, 2005 | 06:56 PM
Imennoharm's Avatar
i got a smoking engine that i suspect is a bad rubbers in the motor as the thing does have 200000+ miles...
i was wondering where you think that i could get a rebuild or something that i could throw into the damn thing or rebuild...
i am trying to do this on the cheap... would cracking open the motor and maybe just those seals being the only problem and replacing those be the best option?
or would just trying to get a used motor that has about 50,000 miles on it be an option?
a pointer in the right direction would be nice... thanks
Old Sep 23, 2005 | 02:27 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Ummm.... what kind of car? You can get used engines fairly cheap. Rebuilds, not so much with being cheap.
Try the For Sale Section... or your regional forum to find a local shop...
Old Sep 23, 2005 | 02:37 PM
Curtisleeyoung's Avatar
If your going to crack open the engine you might as well rebuild the entire thing. If I were to replace an engine I would only do it with an engine that has less than 30K on it.
Old Sep 23, 2005 | 03:21 PM
Mahjik's Avatar
Mr. Links
With that many miles, chances are that the apex seals are worn and out of spec. Most likely other things (bearings) would need to be replaced as well. I doubt you could get away with a rebuild of only replacing the coolant seals.
Talk to Kevin at Rotary Resurrection: http://www.rotaryresurrection.com/
von
Apr 30, 2002 03:58 PM
SPOautos
Mar 19, 2002 12:16 AM
von
Mar 7, 2002 10:44 AM
von
Rotary Car Performance
Feb 13, 2002 12:22 AM
