Power FC Anyone know what sensor "cat" might be?
Old Sep 19, 2005 | 05:53 PM
Sacker90's Avatar
Aint no broke nigga
My car doesn't start with a pfc, but does with stock ecu...I read all the same sensors as my friends except for the "cat" sensor on the sensor check screen..anyone got a idea what that is?
Old Sep 19, 2005 | 06:01 PM
dhahlen's Avatar
FD Under Construction =P
This might be a topic for the ECU forum section, but I believe it is either one of two things.
Either the ECu thinks the cat is too hot, and will not start.... I am not sure if there is a sensor that goes from the air pump to the cat or not...
Did you pull the pins for your power FC? There are 4 wires that have to be cut, or remove the pins from the power FC, if you didn't do this... you're going to have problems.
Old Sep 19, 2005 | 06:31 PM
Sacker90's Avatar
Aint no broke nigga
there is no cat and the wires are cut...
Old Sep 19, 2005 | 06:36 PM
dhahlen's Avatar
sometimes if you have a sensor error, you can throw a resistor inbetween the pos and negative and get the sensor to read. Never had this problem, so I am not sure on what it is. I'll look around and if I come up with something I'll post.
Old Sep 19, 2005 | 06:46 PM
poss's Avatar
Slower Traffic Keep Right
Catalyzer Thermo Sensor Switch of course!!
I actually have no clue what it's referring to except maybe the overheat exhaust light. I've never even noticed it before.
Old Sep 19, 2005 | 07:58 PM
Sacker90's Avatar
Aint no broke nigga
alright...I am totally stumped on this.
Old Sep 20, 2005 | 02:38 AM
dhahlen's Avatar
Give Steve Kan a call @ Gotham, he knows the PFC quite well... he could tell you where to look =P
Old Sep 20, 2005 | 08:28 AM
Sacker90's Avatar
Aint no broke nigga
whats the number or email?
Old Sep 20, 2005 | 02:11 PM
dhahlen's Avatar
www.gothamracing.com =)
Steve Kan Tech Support. Steve@gothamracing.com
PHONE 817 788 8726
FAX 817 788 8731
Old Sep 20, 2005 | 07:37 PM
Sacker90's Avatar
Aint no broke nigga
fixed it....CAS wire was messed up...I talked to Steve and he said the stock ecu will still read pulses or something...I didn't quite understand, but it worked! Thanks dhahlen
Old Sep 20, 2005 | 08:45 PM
dhahlen's Avatar
No problem, glad you got it figured out.
Old Sep 29, 2005 | 06:02 PM
DCrosby's Avatar
No it's not Turbo'd
Ah, big difference between CAS & and CAT, what a difference a "S" makes when troubbleshooting someting
Old Sep 29, 2005 | 08:55 PM
pluto's Avatar
glad that was the problem we talked about, I figured that you probably thought I was full of it when I said it was the wiring that goes to the trigger sensor but I had seen this problem half a dozen times already so I figured that was where your problem was.
maybe i should start charging for phone call questions from now on...... j/k
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
