Sponsored by: CARiD
Keeps Flooding!!!!
Old Sep 16, 2005 | 01:45 AM
jilongie's Avatar
Keeps Flooding!!!!
hello guys
my car keeps flooding
if i let it sit there for like 2.5+ hours
well most of the time.
and Definatley EVERY MORNING...
if it does get flooded,
it'll either take about a FULL minute to actually ignite
or
can't start at all unless i push started it.
when i can't start,
it'll crank really slow, that it can't pick up speed to keep it running.
i called mazda, asking what i should do
they said i should let my car cool down at least like 3 minute
one day, i did it for 5 minutes,
and it was still flooded.
plz help
my car is 89 rx7 n/a
Old Sep 19, 2005 | 06:17 AM
trochoid's Avatar
Old Fart Young at Heart
Send your injectors out and have the cleaned. Leaking injectors is the #1 reason for flooding.
Old Sep 23, 2005 | 05:53 PM
Curtisleeyoung's Avatar
It would also be good to have your starter rebuilt to help with the craning. The injectors are probably bad, cleaning them will do only so much. Durring the night when temps drop down so does the resistance accross the injector coil, if they are bad or close to being bad it' causes them not to close and leaking occurs.
I believe I have some info in the forum section of my website check it below.
Old Sep 25, 2005 | 03:06 AM
jilongie's Avatar
Thanks guys, my problem is solved.
it was my battery, and it wouldn't charge.
So my starter didn't spin fast enough when i started it.
it went away with my new battery. Thanks guys
Old Sep 25, 2005 | 04:02 PM
coo, less work for you then.
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
